alfa boxer 16v ignition mapping
Post new topic   Reply to topic    Alfa Pages Forum Index -> Motorsport, Racing & Trackdays
baldy
PostPosted: Fri Jan 19, 2007 2:08 pm    Post subject: alfa boxer 16v ignition mapping Reply with quote
Hi, ive rcently purchased a megajolt ignition system for my alfa sprint 16v carbed this uses the idis4 distributorless ignition coil system.as the distributor from the 1.7 8v is currently on this engine and was not enabling good cold starting(advance curve) i am looking for a safe ignition map for my engine 1.7 16v boxer so i can drive to the rolling road safley. can anyone help please
baldy Smile
stedee
PostPosted: Fri Jan 19, 2007 2:27 pm    Post subject: Reply with quote
tow it there
brum brum
PostPosted: Fri Jan 19, 2007 2:39 pm    Post subject: Reply with quote
Safe would be just well retarded, and avoid busy traffic. Don't bother with a curve and keep the revs low. But still potential for mistakes.
Think there is an ignition timing map for some of the cars in one of the 33 workshop manuals (series 2 supplements I think). I will try and dig it out.
Isn't there a default safe map with the ignition system?
baldy
PostPosted: Fri Jan 19, 2007 3:19 pm    Post subject: Reply with quote
thanks Keith, i will have a look at the older engines spec and try to use the figures from them as a temperary measure should be close enough for a steady drive.
neo
PostPosted: Mon Jan 29, 2007 1:12 pm    Post subject: Reply with quote
I have one. I`ll post it when I get home from work.
http://www.quartermile.ws/forum/viewthread.php?tid=889&page=1
neo
PostPosted: Sun Feb 11, 2007 4:03 pm    Post subject: Reply with quote
I was using this map for my ignition on 16V engine. Use with 98 octane fuel.
Compression ratio was 10.5:1.
Check that the mixure is rich enough or else you'll get slight detonation over 5500 rpm. Or you can retard the ignition by 2°.
Post new topic   Reply to topic    Alfa Pages Forum Index -> Motorsport, Racing & Trackdays All times are GMT + 1 Hour
