16v ecu diagnostics
PostPosted: Wed Mar 19, 2008 10:39 pm    Post subject: 16v ecu diagnostics Reply with quote
Does anyone know if the software that is in the Alfa garages diagnostics box of tricks is available? I’d like to put it on a laptop and have all readings on screen.
Thanks
I am not interested in the blink code or anything else. Instead of buying one of the main dealers box of tricks, which do all makes of cars, i just want the 33 program running from a laptop.
Thanks again
bobbber
PostPosted: Wed Mar 19, 2008 10:40 pm    Post subject: Re: 16v ecu diagnostics Reply with quote
Thanks again
You don't want much! Laughing
Bob
Fiat Bravo 165 Sport
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Wed Mar 19, 2008 10:42 pm    Post subject: Reply with quote
Saves wasted posts of people suggesting what I don’t want. Tell me what you want, what you really really want, I want a 33 aghhhh
PostPosted: Wed Mar 19, 2008 10:45 pm    Post subject: Reply with quote
I think those main dealers diagnostic box's just get updated via pc, when a new make / model of car comes out. So if one could get hold of the update for a 33 and the software that is run in the box, one could emulate it on a pc.
PostPosted: Thu Mar 20, 2008 5:00 am    Post subject: Reply with quote
I'm after what zenith is doing but with a gui
All the stuff i have found is for obd, i found various software, eg vag com and stuff for the 146.
As i understand it there is a k-line and l-line on the 3 pin ecu diognostic connector. The l-line is used to wake the ecu and the k-line is the ISO data to and from the ECU
ZeNiTh-PbArM
PostPosted: Mon Mar 24, 2008 12:17 pm    Post subject: Reply with quote
ML4.1 system has very little diag functionality.
When the system appeared, Alfa first sold a blink code tool to diagnose it (that was on '86 alfa75 models fitted with underhood circular diag socket)
In '88, Alfa developed and sold the first real diag unit to its dealers, it was called Alfa Tester (and its siamese brother the Fiat Lancia Tester)
This unit was able to diagnose the ML4.1 as well as other systems, and selection of the system was made through switching of cartridges containing the specific program for a particular system ; the cartridge system was very similar to the system used by Nintendo/Sega to run different games on the same console.
Reverse engineering of the unit is quite uneasy, the unit uses an uncommon and undocumented Hitachi processor along with proprietary peripheral circuits.
The ML4.1 has the nasty habit of breaking communication from time to time (this includes during starting), and the Alfa tester was never able to keep communication with the ECU alive with engine running.
In '93, Alfa replaced the good old Alfa Tester with a PC-based product called the Examiner. This diag tool is basically a PC computer fitted with CD reader, printer port, and comprises a specific interface card ; updates were available through CDROM.
This unit was replaced by the Examiner II, more powerful computer, tactile screen, DVD updates, whatever...
Reverse engineering of these is quite difficult, while update DVDs can be found quite easily. Half of the software is running on the computer, and all of the communication software is in fact run on the interface card (read : firmware). Once again hardware is proprietary, and you'll have to go through most of the compiled garbage (a whole DVD!) to extract what you need.
I've gone another route and reversed the ECU, it's quicker and easier.
My first circuit has proven to work satisfactorily.
I've made an update to the board to provide a workaround to spurious comm interruptions
I've designed my interface to provide serial communication with a PC, which will make it possible to develop a computer-based display interface.
I'm currently working on the final development phase and first samples should be available soon. I'll keep you informed.
With best regards,
zp
PostPosted: Mon Mar 24, 2008 5:38 pm    Post subject: Reply with quote
Sweet Smile
gritsop
Looks cool Shocked Any chance that the tester connects to the L-Jet system?
Regards,
Thanassis Gritsopoulos
1991 Alfa 33 1.4 IE
2001 Alfa 147 1.6 Distinctive
http://www.alfa-restoration.co.uk
Parts Shop: www.alfa-restoration.co.uk/shop
etj987
Alfa Arna
PostPosted: Sun Apr 13, 2008 3:28 pm    Post subject: Diagnos Reply with quote
ZeNiTh-PbArM
For an amatur it seems you`re doing a great job.
As a newcomer on this forum I would very much appreciate if you would like to update me on current status of the project and if you have any plans for the L-jetronic common on 8v 1,7IE.
Do you plan to make these testers available for the rest of us less skilled in programming?
At present my 33 needs proper diagnosis. I have a very week spark and current plan is to get a donor 33 and swap components one by one.
I have done the normal distributor cap, cables and coil change but no cure.
Regards.
Alfa 33 1,7IE 1992
ZeNiTh-PbArM
PostPosted: Mon Apr 14, 2008 9:02 pm    Post subject: Reply with quote
Still working on the units, anyhow L-jetronic has very little diag functionnality and is not currently targeted.
However, having experienced weak spark problems on this system, i would suspect the ignition amplifier final stage. The transistor is likely to have burnt. Be sure to check on the coil too, as a partially shorted coil might have been the cause of amplifier failure.
Besides, check the obvious, i once had a dizzy cap and rotor replaced by a poor quality/wrong model/counterfeit spare part, and the rotor arm resistance deteriorated over a few days, which resulted in a fried ECU and a stranded car.
regards,
zp
etj987
Alfa Arna
PostPosted: Tue Apr 15, 2008 8:14 pm    Post subject: Reply with quote
Hi ZP
Thanks for your help.
I am not familiar with the expression ignition amplifier - is that the transistorized distrubutor?
As I understand your explenation you recommend me to swap both coil and distributor.
Alfa 33 1,7IE 1992
ZeNiTh-PbArM
PostPosted: Sun Apr 20, 2008 9:18 am    Post subject: Reply with quote
Yes amplifier is the module fitted on the distributor.
regards,
zp
gritsop
PostPosted: Thu May 01, 2008 9:48 pm    Post subject: Reply with quote
ZP since the distributor has just a multipole connector and no obvious signs of electronics, isn't this amplifier module located at the black box just behind the battery?
I opened it up and here is a photo of the circuit
1991 Alfa 33 1.4 IE
ZeNiTh-PbArM
PostPosted: Fri May 02, 2008 5:43 am    Post subject: Reply with quote
From the looks of it this is an ignition ECU, which computes ignition advance.
33s fitted with carbs had a module either on the dizzy (bosch system) or under the coil (marelli system)
regards,
zp
PostPosted: Wed Nov 18, 2009 4:02 pm    Post subject: Reply with quote
ZP
Any update?
are they for sale yet?
33bits
PostPosted: Wed Nov 18, 2009 8:29 pm    Post subject: Reply with quote
I seem to recall Kieth picking up a "box of tricks" diagnostic set at the Auto Italia Stanford Hall event last year. Confused
155 sportpack
