vantastic Alfa Sprint
Posted: Wed Mar 27, 2013 8:53 pm Post subject: Wheels and mirror |
After some 5 spoke speedlines (like 155 ones) and N/S mirror as mine seems to wobble a bit, the adjuster seems to be not connected, will have to look closer at that, also I take it 16" wheels wont upset the P4, I know about the hub size bit. _________________ P4 33......Fratellino (black)
V6 75 3.0.....Marmite
V6 155....Cristine (24v 3.0 Q2) spazio |
Posted: Wed Mar 27, 2013 9:03 pm Post subject: |
I had a look at my mirror last year and the lever that controls the movement attaches by 3 short wire cables which attach to the centre of the plastic back plate that the mirror is bonded to, if your mirror glass is loose then posibly 1 or 2 of the cable have become detached. If its the whole mirror that wobbles then you may have a cracked large circular castle nut that holds the mirror to the door. _________________ PHAT 33 |
Posted: Wed Mar 27, 2013 10:00 pm Post subject: |
Oggie wrote: |
I had a look at my mirror last year and the lever that controls the movement attaches by 3 short wire cables which attach to the centre of the plastic back plate that the mirror is bonded to, if your mirror glass is loose then posibly 1 or 2 of the cable have become detached. If its the whole mirror that wobbles then you may have a cracked large circular castle nut that holds the mirror to the door. |
Both ... _________________ P4 33......Fratellino (black)
Ian M Green Cloverleaf
Posted: Thu Mar 28, 2013 9:41 am Post subject: |
I think I seen a set of speedlines for sale on Alfa Owner recently _________________ Presntly own
Red Abarth 500c |
Posted: Thu Mar 28, 2013 6:43 pm Post subject: |
Did have a bid on these, but outbid _________________ P4 33......Fratellino (black)
ALFADELTA1975 Alfa Arna
Joined: 22 May 2005 Posts: 12 Location: The Netherlands
Posted: Wed Apr 03, 2013 8:23 am Post subject: |
I know on a dutch clubsite someone is selling the speedlines in 16inch. I'll drop the link here if I find it. |
Posted: Wed Apr 03, 2013 8:01 pm Post subject: |
ALFADELTA1975 wrote: |
Not speedlines but thanks for the link  _________________ P4 33......Fratellino (black)
