Transformation, 8v becomes a 16v.
33bits
PostPosted: Fri Jan 23, 2015 10:49 pm    Post subject: Transformation, 8v becomes a 16v. Reply with quote
Thought you guys might like to see my latest little project. Steve Lilly in Essex who has had his lovely 1.7 ie 33 for about 6 months missed the grunt of his previous 16v, so asked if i could supply & fit all the relevant bits to fully convert his car in to a 16v model. I'm cracking on with the job..........
Steve's ie in standard form.
After changing bumpers, mirrors, side skirts, wheels, fitting a spoiler, a set of headlight washers it rapidly started to look like a 16v.
Then the interior was replaced with a P4 set along with the nardi steering wheel.
155 sportpack
33bits
PostPosted: Fri Jan 23, 2015 10:53 pm    Post subject: Reply with quote
Then the engine was promptly removed & the 16v loom fitted ready for the bigger lump.
155 sportpack
33bits
PostPosted: Fri Jan 23, 2015 11:00 pm    Post subject: Reply with quote
16v lump ready to fit.
All new 16v springs & shocks fitted too.
A lovely set of Brembo discs, OMP pads and re-furbed callipers supplied by Rich B, many thanks Rich.
155 sportpack
33bits
PostPosted: Fri Jan 23, 2015 11:03 pm    Post subject: Reply with quote
Engine is now bolted in place and all the plumbing in is on the job sheet for tommorrow. Also need to sort out the exhaust system & change the carpet from grey to black.
phew
155 sportpack
greencloverleaf pat
PostPosted: Sat Jan 24, 2015 11:59 pm    Post subject: car Reply with quote
Nice work Alex did it take you long to do the swap over.
Also do you know of anyone who has some recaros as I want some for my sud .
The Wombat
PostPosted: Mon Jan 26, 2015 7:56 pm    Post subject: Re: car Reply with quote
I have several sets of recaros from P4s and late 16vs. I have a set of the alcantara recaros although they need a damn good clean.
Was looking for about 100 quid for a set.
Drivers:
- Green Fiat 20VT Coupe
- Champagne 155 V6
- Winter Freelander
- Mrs Wombats Freelander
Projects:
- Various 33s
- Some 155s
Hibernating for 2015
- 75 3.0 Cloverleaf
- 155 Q4 Winny
- Red 33 16v
greencloverleaf pat
PostPosted: Tue Jan 27, 2015 6:25 am    Post subject: seats Reply with quote
Pm sent
33bits
PostPosted: Wed Jan 28, 2015 11:25 pm    Post subject: Reply with quote
Hi Pat, no sorry i havn't got any seats at the mo, only standard 8v stuff and a few pairs of bucket race seats coming on the weekend. If Niel has a set for £100 ish i'd get in there and give him a wedge of dosh. Very Happy The 16v conversion didnt take too long, i trailered the car here from Essex on 8th Jan, Steve will have it back all done on 3rd Feb. (fingers crossed)
155 sportpack
33bits
PostPosted: Wed Jan 28, 2015 11:39 pm    Post subject: Reply with quote
16v in pretty much plumbed up.
Hard at work
155 sportpack
33bits
PostPosted: Wed Jan 28, 2015 11:41 pm    Post subject: Reply with quote
She runs Exclamation all sweet, exhaust is on and grey carpet is now black. Project is almost complete.
155 sportpack
33bits
PostPosted: Wed Jan 28, 2015 11:53 pm    Post subject: Reply with quote
Now have the ie 8v lump to move on if anyone is interested.
155 sportpack
PostPosted: Tue May 30, 2023 5:35 pm    Post subject: Reply with quote
This will be for sale in less than 6 mnths
Just had a new M.O.T, please look online for advisories
Previous owner did not look after this!!
Coolant was rusty sludge and small return pipe was blocked.
dizzy cap was on the wrong way round and loose!
head studs were missing and bolts were used!
rear drum shoe adjuster ratchet springs were missing both sides
I have replaced;
both rear cylinders and shoes
added 1 ratchet spring, I have 2 new whole adjuster mechanisms
flushed the coolant system and cleared the blocked pipe
fitted new exhaust head studs.
all new intake and exhaust valves, valve stem seals, head gasket on O/S head
cam belts
oil and filter
Power steering and alternator belts
repaired brake pipes, Alex made a complete front to rear set, I will pick up at NAD
changed interior for alcantara
2 new tyres, fitted to the rear
new front pads
PostPosted: Tue Jun 27, 2023 10:50 am    Post subject: Reply with quote
I and the car will be at Nation Alfa Day 2023 for perusal
https://www.tickettailor.com/events/alfaromeoownersclub/940269
people interested
1 david F
2 Anthony
