Getting too much fuel - fat mixture
BillaBoo
PostPosted: Mon Nov 17, 2008 10:58 am    Post subject: Getting too much fuel - fat mixture Reply with quote
Hi!
Got a 33 16v that gets a too fat mixture
I ve changed the following;
Lambda, Plugs, plug-wires, idle valve, injectors, cleaned airfilter..
But the idle is still bouncy, and it can drown if i`m not rev`ing it.
any ideas?
1990` AR 33 16v
-CSC exhaust, yellow koni, h&r springs, k&n airfilter, squadra chip.
PostPosted: Mon Nov 17, 2008 5:18 pm    Post subject: Reply with quote
if the cold start sensor CTS (coolent temperature sensor) is giving a faulty reading, as in the engine is cold then it will overfuel. I have posted about this, look at http://www.alfa-pages.co.uk/viewtopic.php?t=5575&highlight=cts
10th post down, hope that helps
PostPosted: Mon Nov 17, 2008 6:30 pm    Post subject: Reply with quote
How can you tell if a fuel injected car is overfueling or underfueling?
PostPosted: Mon Nov 17, 2008 7:30 pm    Post subject: Reply with quote
I think if the fuel pressure is where it should be then you check the emissions before the cat and adjust with mixture screw, disconnect lambda if one is fitted. If it is still out after and with lambda re connected then i would be stumped, as i am with mine
BillaBoo
PostPosted: Tue Nov 18, 2008 9:26 am    Post subject: Reply with quote
My spark-plugs is getting black of.. (i dont know the english word for it, but you get my point). And idle is crap, sometimes you can hear it drown, and i have to carefully rev it..
This cts sensor. Where is it located?
BigAl - mixture screw? do i have one? i thought this was all controlled by the onboard computer(brain, head unit .. )
1990` AR 33 16v
PostPosted: Tue Nov 18, 2008 5:15 pm    Post subject: Reply with quote
The CTS is on the front left throttle body "as you sit in the car", it has a blue plastic on it. i would take a reading from the extension lead tht comes off of it.
You are correct, the ECU and AFM manage fuel mixture but it needs a correct base line which changes if the ECU or AFM have been changed. If so then you need to tell the ECU that no lambda sensor is connected and then check the emissions before the cat and adjust with the screw which is on the front of the AFM and is normally covered with a plastic cap.
PostPosted: Sat Nov 22, 2008 2:04 pm    Post subject: Reply with quote
any update? did you find a probe small enough to get in hole before cat and set up fule mixture?
BillaBoo
PostPosted: Sun Nov 23, 2008 11:35 pm    Post subject: Reply with quote
Hi.
Havent got to do that just yet. Gonna try the afm first. if that doesnt work, i might change some temp sensors. is there possible to do a diagnostic check on theese old alfas?
1990` AR 33 16v
PostPosted: Tue Nov 25, 2008 2:55 am    Post subject: Reply with quote
BillaBoo wrote:
Hi.
Are you going to change the AFM or clean the temp sensor in it?
There is a diagnostics, called the Alfa tester which does live readings, or there is a home made tester that just reads of stored faults in the form of blink codes.
I had a play around with mine today, I couldn’t put the gas analyser before the cat but in the tailpipe. When I removed the timing relay telling the ecu that no lambda sensor is connected it was way to high. I had to turn it 4 times clockwise before it read proper co, looks like it would pass without the lambda connected. When I connected the lambda, by changing the timing relay and telling the ecu that the lambda is connected it was way out, need a new lambda sensor, or to set it up by measuring before the cat.
So adjustment does work, I will do it properly next time.
PostPosted: Wed Dec 03, 2008 9:25 pm    Post subject: Reply with quote
I still havent had a chance to do mine properly, what about you BillaBoo?
