clutch lever
RBL
PostPosted: Mon Feb 09, 2009 10:58 am    Post subject: clutch lever Reply with quote
I'm looking for the forked clutch activation lever that the slave cylinder pushes on. Anyone got one? (without much wear to the pivot hole if possible)
Rich
Porsche 550 spyder replica with Alfa Sprint 1.7 engine
PostPosted: Mon Feb 09, 2009 2:48 pm    Post subject: Reply with quote
I've got one here that's in pretty good shape.
PostPosted: Mon Feb 09, 2009 3:29 pm    Post subject: Reply with quote
Just dug it out! Is this going to be any good? The hole is in good condition.
RBL
PostPosted: Mon Feb 09, 2009 3:37 pm    Post subject: Reply with quote
That looks great, thanks. I'll send you a PM
Rich
rafforacer
PostPosted: Wed Mar 11, 2009 2:38 pm    Post subject: Lever mod.... Reply with quote
While you are at it, can I recommend you make it stronger?
We have heard that these do actually bend!
Simple mod is to get a plate welded onto the "open side" with a hole in
where it fits onto the peg in the gearbox.
ie. drop the lever onto a piece of paper "engine" side up, and draw around it. Make this shape in steel.
Spot through the peg hole too.
Open this hole up to around 20mm dia. to fit over the boss in the gearbox.
Weld the profile to enclose the lever, making it into a box section.
-Job done!
Hope this helps,
Best,
Gra.
tvatavuk
PostPosted: Thu Mar 12, 2009 3:17 pm    Post subject: Reply with quote
Yes those forks can bend which sometimes can cause bearing failure but sometimes it's other way around.
If you make it stronger it means that stronger force will work/be transfered to something else. Are you sure you wanna do it? Sometimes car parts are built intentionaly so more expencive parts wouldn't be damaged.
ie stronger fork hole wil bend more easily pin it can even break it off from gearbox bell....
Tino Vatavuk
