Tachometer not working
Alfa_33_Veloce
PostPosted: Tue Aug 26, 2003 7:47 pm    Post subject: Tachometer not working Reply with quote
I've just brought an '88 alfa 33 1.5ti veloce - my first alfa romeo. I brought it knowing there are a few minor things wrong with it. Most I have managed to solve but with the little knowlage i have i still cannot get the rev counter to work. Could anyone help me out?
One last thing could anyone tell me what the ''ti'' stands for thanks a lot.
** alfa 33 Veloce **
johnboy
PostPosted: Tue Aug 26, 2003 8:08 pm    Post subject: Re: Tachometer not working Reply with quote
[quote="Alfa_33_Veloce"]I've just brought an '88 alfa 33 1.5ti veloce - my first alfa romeo.
Good man joining the chap's Cool
the rev counter work's off the coil,i think it's the white wire on the coil,check that. all the best john
WODA WE NEED? MORE POWER!!
1999 freestyle superjet
gritsop
PostPosted: Tue Aug 26, 2003 10:04 pm    Post subject: Reply with quote
Hi from Greece,
Welcome to the alfist team of the legendary 33 model!!!
TI stands for Tourismo Internazionale. The same as GT.
Basically it means a more equipped car including various elements like instrument panels , diagnostic readings, a more sporty look including rims, spoilers etc.
Please feel free to ask anything that you may encounter.
Thanassis Gritsopoulos
Eddie W
PostPosted: Tue Aug 26, 2003 10:58 pm    Post subject: Reply with quote
HI VELOCE
Check the plug that joins the main loom to the dash loom. It`s near the brake master cyl. Aflat black plug seperate from the main wiring. The cable is shielded like an aerial so it doesn`t pick up stray signals. They often give problems at this connection.
Good luck Eddie
Alfa_33_Veloce
PostPosted: Wed Aug 27, 2003 5:40 pm    Post subject: Reply with quote
Thanks for your replies they have been really helpfull.
Alfa_33_Veloce
PostPosted: Sat Aug 30, 2003 8:47 pm    Post subject: Reply with quote
Ive checked all the leads and cant find the problem.
could it be somthing wrong behind the dash? I heard it was an awkward job taking the dashboard off, so i didnt really want to try.
Gary UK
PostPosted: Sat Aug 30, 2003 10:56 pm    Post subject: Reply with quote
No, taking the speedo console off on the 33 is easy, just a couple of screws.
Eddie W
PostPosted: Sat Aug 30, 2003 11:37 pm    Post subject: Reply with quote
You need access to a continuity tester (a lot of multi meters have this facility) and check each segment of the loom right up to the tacho itself. One of my cars had a wire soldered between the point where the loom enters the back of the dash and the tacho unit itself, so there must have been a break in the printed circuit. A continuity tester would help you find such a problem. Also you can check for circuit across that plug I mentioned before.
Good luck Eddie
