fit oil cooler
guest
PostPosted: Thu Sep 11, 2003 11:53 am    Post subject: fit oil cooler Reply with quote
I live in Queensland Australia and during summer it can be around 35 + degrees . were is the best place to for pickups for an oil cooler . I am going to use the air con condenser as a cooler as the air con no longer works but the sun roof lifts out . Question
Scott Sander
PostPosted: Thu Sep 11, 2003 12:25 pm    Post subject: Reply with quote
Fit an adaptor between the oil filter and the mounting point for the oil filter. That is what everyone else seems to do that fits an oil cooler to our boxer motor.
Scott Sander
http://www.sanderfamily.com
Marcin
PostPosted: Thu Sep 11, 2003 4:06 pm    Post subject: Reply with quote
does anyone know how hot the oil actually gets without an oil cooler? How much should it be cooled down, i.e. what's the optimum operating temperature?
Marcin
Eddie W
PostPosted: Fri Sep 12, 2003 4:30 am    Post subject: Reply with quote
I`d be bloody carefull about running oil pressure through an aircon core! They are not designed for such pressures. If you still want to try it, you should fill it with water and apply at least 70psi air pressure to it. The results of a failure at full noise on the motorway don`t bear thinking about!
Regards Eddie
Eddie W
PostPosted: Tue Sep 16, 2003 10:48 pm    Post subject: Reply with quote
Checked into this a little further, pressure MIGHT be OK but flow is insufficient.
Regards Eddie
Gary UK
PostPosted: Thu Sep 18, 2003 12:30 am    Post subject: Reply with quote
From memory the old golf GTI Mk I & II oil cooler pick-up from oil filter, pipework and cooler element would be ideal for the 33 and would bolt straight on with very little alterations. And as the engines are roughly the same size with similar oil capacities this would also make it an ideal donor plus there are plenty of cars around to cannibalise. I think that the element is short enough to be placed vertically alongside the radiator
