anyone got a knackered 16v I can rob some part from?
Edward
PostPosted: Fri Oct 17, 2014 11:46 pm    Post subject: anyone got a knackered 16v I can rob some part from? Reply with quote
I need:
small blue plugged cable that goes to the N/S temp sensor in the bottom of the throttle body
Injectors and fuel rail
Starter motor and spacer
Aluminium airbox
throttle linkage plastic ended connectors
Plastic cam box covers
Dipstick
Loom (but not ECU)
Flexible oil ways from head to block.
I have raided most of Alex's stuff already. If you have such parts can you let me know - cheers - Edward 07920 070762
The faster the better.
33bits
PostPosted: Sat Nov 08, 2014 10:16 pm    Post subject: Reply with quote
Sorted now me thinks........
155 sportpack
Edward
PostPosted: Sat Nov 08, 2014 10:52 pm    Post subject: Reply with quote
Yep Alex........ you are the man!
smusician
PostPosted: Fri Sep 04, 2015 7:12 pm    Post subject: Reply with quote
Hi I have a complete 16v 1.7 flat four engine all in bits in a box that I started rebuilding but I have sold my 33 and is sat in my garage getting in the way! I am open to sensible offers on! I also have quite a few other bits kicking about 17yrs worth to list as thats how long I owned my 33
The Wombat
PostPosted: Sat Sep 12, 2015 8:00 am    Post subject: Reply with quote
Do you have the block/rotating assembly?
That is the block with good crank/conrods/pistons etc
I have a 16v with number 3 big end gone and possible crank damage/con rod gone oval, and anither engine with internal condition unknown and belt snapped (OS head is destroyed, valve stem through water galleries)
Having a known good crank and conrods would incentivise be to build up a good engine!
Drivers:
- Green Fiat 20VT Coupe
- Champagne 155 V6
- Winter Freelander
- Mrs Wombats Freelander
Projects:
- Various 33s
- Some 155s
Hibernating for 2015
- 75 3.0 Cloverleaf
- 155 Q4 Winny
- Red 33 16v
