non starting 33. starter motor exciter wire not got enough..
Goto page Previous  1, 2
eagle3
PostPosted: Thu Oct 01, 2015 4:26 am    Post subject: Reply with quote
A faulty ignition switch has similar symptoms. I'm surprised you haven't at least tried another.
I was crossing fingers in my C15 every time I started it. Not that that helped. It was completely random. Although by the time I go round to changing it the thing had become progressively less and less reliable.
A simple wire to be used from the solenoid to the + terminal was in the glove box if required. Since changing the switch this has not been needed.
Alfa33 QO 1984
Alfa33 1.3i.e. 1994
PostPosted: Thu Oct 01, 2015 6:12 pm    Post subject: Reply with quote
I have never changed one before. Are there security bolts that have to be drilled out? If I can get away with not having to change it.... Smile
eagle3
PostPosted: Fri Oct 02, 2015 8:47 am    Post subject: Reply with quote
No drilling.
I had to change mine after the car was broken into. You have to turn the key to a certain position which allows you to push the button in on the side to slide it out. No very difficult.
Alfa33 QO 1984
Alfa33 1.3i.e. 1994
PostPosted: Sat Oct 03, 2015 1:45 pm    Post subject: Reply with quote
ahh ok, what about the key, can you change the barrel so you can still use the original key?
eagle3
PostPosted: Sun Oct 04, 2015 6:02 am    Post subject: Reply with quote
There might be a way but I wouldn't try taking them apart. I did once on an old one but ended up destroying it. Embarassed So now I have a separate key for the ignition.
You can get the ignition switch and two door barrels to keep one key for all,
One here in Paris http://www.leboncoin.fr/equipement_auto/824349130.htm?ca=5_s
You need to check whether yours is three- or four-wire. This one off a late 1.4i.e is four-wire http://www.leboncoin.fr/equipement_auto/734657085.htm?ca=5_s
Alfa33 QO 1984
Alfa33 1.3i.e. 1994
PostPosted: Mon Oct 05, 2015 12:22 am    Post subject: Reply with quote
Thanks I'll bear that in mind. I have one key for ignition doors and petrol cap, rather keep it that way Smile
I'm hoping I don't have to change it.
Page 2 of 2
