PAS fluid in this day and age
PostPosted: Sat Jun 20, 2020 11:45 pm    Post subject: PAS fluid in this day and age Reply with quote
manual says
agip dexron II
ip dexron fluid II
tutela GI/A
i am assuming this is ATF not PSF
i have 1L of
https://www.commaoil.com/commercial-vehicles/products/view/223/PSF1L
it says "Compatible with all ATF type fluids. " ???
https://www.opieoils.co.uk/f/102203/103/1992/power-steering-fluid.aspx
suggests
Motul DEXRON IID
Motul DEXRON III
Motul MULTI ATF Fully Synthetic.
It is strongly prohibited to mix mineral, synthetic and semi-synthetic fluids with each other.
https://www.eurocarparts.com/steering-fluids
suggests
TRIPLE QX ATF Dexron III
TRIPLE QX ATF Plus Transmission
TRIPLE QX Multi Vehicle ATF-U - 1
Castrol Power Steering Fluid
https://www.autodoc.co.uk/car-parts/power-steering-fluid-12303/alfa-romeo/33/33-907a/8252-1-7-16v-907-a1b
suggests even more different ones
I will be doing a flush btw
what is suggested
Alan
1993 ser 3 silver 16v
RFlower
PostPosted: Sun Jun 21, 2020 8:43 am    Post subject: D Reply with quote
Dexron is a General Motors specification which is widely used by other car manufacturers. I always make sure any ATF I buy for the Alfa steering system is so labelled, as I'm sure that all Dexron specs can be mixed. The different numbers represent small changes/improvements over the years.
That statement "Compatible with all ATF type fluids", is ridiculous, as ATF simply stands for Automatic Transmission Fluid. It is not a type of fluid, and I don't believe all ATF's are mixable.
Nor are all PSF's mixable - my Audi uses a green fluid for the power steering and the manual specifically says not to use any other colour.
Dick Flower, Nr. Carcassonne. '94 Trofeo 1.4 ie (F), '93 Imola 1.3/1.4 ie (now for parts) (F), '91 1.7 ie (GB)(spare car), '86 Sprint 1.5 QV (F). '87 VW Syncro camper (F), '96 Audi Avant 1.8T (F)
PostPosted: Tue Jun 23, 2020 11:15 pm    Post subject: Reply with quote
got this
https://www.halfords.com/motoring/engine-oils-and-fluids/gearbox-oil/halfords-automatic-transmission-and-power-steering-fluid-dii-1l-724930.html
