rain902 Alfa Arna
Joined: 08 Jan 2005 Posts: 4 Location: melbourne australia
Posted: Sat Jan 08, 2005 6:14 am Post subject: 33 electric window problems - pls help??/ |
hello all
the window control switch in my 33 jammed, then melted, and was duly replaced. I am reading voltage at one of the terminals that feed the switch however the new switch wont run the windows. An examination of the winder motors shows them to work very well so the problem is most probably either a relay or voltage feed issue. Suffice to say that i checked all fuses however i have no clue as to which relay(s) are part of the window circuit.
Does anyone have a circuit diagram for the 33?
Does anyone have experience with this problem and can point me at the correct relay to inspect or change?
many thanks
teruo |
Posted: Sat Jan 08, 2005 6:47 am Post subject: |
What model 33 do you have?
Do both the electric windows not work, or is one broken and the other functional?
Do you have a multimeter to test that the new switch works? |
rain902 Alfa Arna
Posted: Sat Jan 08, 2005 8:34 am Post subject: |
its an 84 carby 1500cc model
both windows have ceased to operate.
i have attempted to check switch functionality with m/meter - there is a change of state across some contacts however i do not know which ones are supposed to be changing state when the button is pressed. |
Posted: Tue Jan 11, 2005 4:21 am Post subject: |
Relay is behind centre console, not far above g/box tunnel.
AB Guest
Posted: Fri Jan 14, 2005 2:28 pm Post subject: electric windows |
have you test the cables ? (they are often broken near door hindge) |
