conrods
neo
PostPosted: Sun May 01, 2005 7:04 pm    Post subject: conrods Reply with quote
Hi!
Can anyone post me a picture or explain me the conrods orientation? I've looked in the workshop manual but on some pictures they are turned one way and on the other pictures the other way. I think that the left bank(cil 2. and 4.) conrods are turned with big end caps facing upwards and the right bank(cil 1. and 3.) conrods turned with big end caps facing downwards, looking the engine from the flywheel side i a normal position. Is this correct?
And on 2 conrods i have a number 64 stamped on and on the other two 63. What are those numbers for?
Thanks!
RFlower
PostPosted: Fri May 06, 2005 1:20 pm    Post subject: Reply with quote
My Alfa 33 manual (dated 1984, but I don't think engine layout has changed since then) says to fit the pistons with the arrows on the crowns pointing in the direction of crankshaft rotation, and to fit the con rods so that the identification number can be read.
The picture shows all the big end caps pointing down.
I don't think you could tighten the bolts if any caps were pointing up?
neo
PostPosted: Fri May 06, 2005 8:58 pm    Post subject: Reply with quote
I've assembled the engine that way in the end. I was confused with that picture in the manual where you can see the engine in exploded view. In that picture the left bank cilinders have the conrods rotated with the big end caps facing upwards.
Thanks!
