TasKiNG Alfa Arna
Joined: 19 Apr 2003 Posts: 2 Location: Derby, England
Posted: Tue May 20, 2003 11:56 am Post subject: At what temperature should the electric fan start |
In traffic jams i have noticed that my temperature reaches 90 deg
I have not heard the fan come on so was wondering at what temp it should turn on.
the car is a 1993 alf 33 1.7ie _________________ Cheers
TasKiNG |
Errol Alfa Sprint
Posted: Tue May 20, 2003 1:59 pm Post subject: |
It allDepends on the fan switch that you have in there. For example , on mine it cuts in at roughly 87C. If it hasnt come on by 95 id be starting to get worried. Try and check the fan switch near the radiator. Unscrew it ( make sure you have a pan underneath the car because coolant will come out ) then check the numbers on there , which will tell you when the fan comes on. If it says something like 88 ( just an example ) but the fan doesnt come on then, then get a mechanic to take a quick look.  _________________ 91 Alfa Romeo 33 16v * SOLD*
Lowered 45mm
15 x 7 inch advanti wheels
Falken 195 low profile
K&N Pod filter
Posted: Wed May 28, 2003 6:33 pm Post subject: |
Cheers errol
I have checked it out and am now happy that it comes on at about 90 deg |
