Posted: Thu Oct 20, 2005 11:23 am Post subject: Idle Bypass Pipe |
Hiya all!
I can move the connection side to side where the Idle Bypass Pipe goes into the front of the intake manifold.
Is this normal???
Thanks!
Posted: Thu Oct 20, 2005 12:01 pm Post subject: |
It can be normal if you are able to rotate it either clockwise or counterclockwise. However I doubt if it is normal to move it side to side.
This pipe is made out of nylon with rubber coating where it meets the manifold. Could it be cracked or so?
Posted: Thu Oct 20, 2005 3:15 pm Post subject: |
Blimey! I'll take it out and have a look!
Thanks!
