markgp4 Alfa Sprint
Posted: Thu Oct 27, 2005 10:16 pm Post subject: Help ... timing |
Hi i have just bought my first 33 16v and it is a non-runner
I have been thro the manuals and i think the timing is wrong...
If the timing is correct at TDC should the "T"`s line up on both sides of engine or just one then the other on the next crank rotation ???
and how do they count 2,3, and 4 cyl? im very confused by this flat 4 manual...
help please ... _________________ make it go faster  |
Kostas Katsanis Guest
Posted: Thu Oct 27, 2005 11:50 pm Post subject: |
The firing order of the distributor, i suppose it's the same for both 8v and 16v, is 1-3-2-4. Now for each cylinder, i think -and correct me if i 'm wrong- that as you look the car from the front side No 1 cyl is the first on the left side, No 2 the first on the left side, No 3 the second on the left side and No 4 the second on the right side. Like that:
3 - 4
1 - 2 |
Posted: Fri Oct 28, 2005 11:49 am Post subject: |
thanks Kostas  |
Posted: Fri Oct 28, 2005 1:39 pm Post subject: |
Yes, Kostas... that's correct.
Posted: Fri Oct 28, 2005 2:05 pm Post subject: |
Hi...
The diagram confused me a bit...
I think its like this:
Front of the car
2 - 1
4 - 3
Rear of the car
Correct me if im wrong???
Posted: Fri Oct 28, 2005 8:34 pm Post subject: |
Thanks people, have sorted it and its running now
Phew........ timing was all wrong  |
