burgo90 Guest
Posted: Thu May 29, 2003 1:39 am Post subject: headlight |
| ne1 kno where i mite b able to get a head light as i may need one |
Posted: Thu May 29, 2003 3:42 am Post subject: |
Your in the UK right?
I can’t specifically help but you could try an Alfa Dealer or maybe a wreckers. Maybe someone in the UK maybe able to help? _________________ Scott Sander
Posted: Thu May 29, 2003 3:10 pm Post subject: |
| yeah im in the uk and its just cos one of the headlights failed the MOT cos it doesnt have a pattern but tis also got condensation in it could this b wot is causing there to b no patern if so then if i just dry it it should b ok right??? |
Lee Alfa Sprint
Posted: Thu May 29, 2003 6:15 pm Post subject: |
If the lense is`nt holed then you can get away with removing the bulb and letting the air dry the condensation to help you pass the mot. If you need a new one Alfa charge over £100 now, but many people here should be able to help with a second hand one
As you say the condensation does affect the patern.
Lee _________________ `97 155 2.0 16v sport
`91 33 1.7 I.E |
alfamad1970 Guest
Posted: Sat May 31, 2003 12:00 pm Post subject: re headlight |
hi let me know what headlight you req which side i mean im in south england
phone 07860 861898 |
burgo90 Alfa Sprint
Posted: Sun Jun 01, 2003 3:31 am Post subject: |
| it seems it was just condensation so i wont b needing one thanks ne wayz ill have some pics of it on here tomoz as well |
Dave_NZ Alfasud
Posted: Sun Jun 01, 2003 11:18 am Post subject: how i fixed my condensation problem |
I had the same problem with condensation so i decided to do something about it. I took the grill and lights off and to my surprise, the lhs headlight unit had come apart. The glass had seperated from the metal housing. I gave it a good clean out and then dried it for a few hours. I then applied silicon bonder to the join and clamped the pieces together, and removed the excess. 24hrs later i had a new light. That was done two months ago and no condensation to date. Also make sure the breather pipe us clear.
Good luck
Dave _________________ Looking for a type 2 33QV in NL |
