struts difference
neo
PostPosted: Mon Jul 10, 2006 10:39 pm    Post subject: struts difference Reply with quote
Hi!
I'd like to know if there are any difference between the struts with 4 bolts?
Thanks!
http://www.quartermile.ws/forum/viewthread.php?tid=889&page=1
stedee
PostPosted: Tue Jul 11, 2006 12:03 am    Post subject: Reply with quote
hi
do you mean the difference between 3 stud and 4 stud legs
if so the springs and shockers are different as i found out to my cost
the springs on 3 stud legs are conical and i believe the shocker is a wider fit.
brum brum
PostPosted: Tue Jul 11, 2006 9:28 am    Post subject: Reply with quote
Hi!
I know that there is a difference between the 3 stud and a 4 stud strut. But I'd like to know if there are more types of the 4 stud top mounts.
Thanks!
tvatavuk
PostPosted: Tue Jul 11, 2006 3:41 pm    Post subject: Reply with quote
Yes there were two types for 4 bolt system.
You could diferentiate them by thickens of shock stub top, or by diameter of hole in rubber part.
1st was used on series 1,2 and few early series 3.
2nd came later and was first used on 1.7 engines.
Main difference is one type was all rubber, while other type has small metallic ring (small shock stub top bearing) inside rubber.
I don't remember which was thicker Sad
Few months ago I replaced both of P4 front strut top mounts, while mounting Yellow KONIs shocks to front, and I know it was real hard to find older type top mount (you had to order them), while newer (one I needed) is available from SKF on shelve in most of AR parts shops.
In each package comes one notorius yellow top strut plastic bearing Smile
Tino Vatavuk
