colin2296fs Alfa Arna
Joined: 21 Mar 2003 Posts: 5 Location: Grangemouth(Scotland)
Posted: Fri Jun 06, 2003 2:57 pm Post subject: 16v tdc |
after changing my engine from a 1.7 8v to a 1.7 16v i am needing to get the spark plug leads on the distributer in the right order.can anyone tell me how to find top dead center on a 16v. there is a plastic plug beside the distributer,is it possible there are marks if i look through the hole or do i need to take the cam belt covers off and find out that way.
thanks for any help given
colin |
graeme Alfasud
Posted: Fri Jun 06, 2003 8:31 pm Post subject: tdc |
There are two marks on the flywheel, one is a "T" one is a "V". TDC is when "T" is adjacent to the pointer with no 1 piston at top of stroke, rotor arm pointing at no. 1 position is distributer.
See
http://www.alfisti.co.uk/16v_boxer_belts.htm
for more info. _________________ 16v p4 In pieces. |
Yvon Alfasud
Posted: Fri Jun 06, 2003 9:39 pm Post subject: |
Yes, the "T" and "V" marks can be seen from the hole when you take the small plastic cap you mention. Check if rotor is also pointing to cylinder #1 (right side of the car and the one near the main radiator).
Cylinders are numbered like this :
3 | 4
1 | 2
radiator
Firing order is : 1-3-2-4
Good luck
Ciao
Yvon |
