idle mixture adjustment on 16V
neo
PostPosted: Tue Oct 31, 2006 7:16 pm    Post subject: idle mixture adjustment on 16V Reply with quote
Hi!
I've measured the emissions of my engine and I got the following results:
CO=2.37%
O2=1%
CO2=9.5%
HC=330 ppm
The car is a non cat and witouth a lambda probe. Engine code is 307.46. The manual says that there should be 1.5% CO. So i'd like to lower it. I know that I can do that by turning that screw on the MAF. But I don't know witch way to turn to get leaner mixture since I don't have access to the gas analizer anymore.
Thanks!
http://www.quartermile.ws/forum/viewthread.php?tid=889&page=1
stedee
PostPosted: Tue Oct 31, 2006 7:23 pm    Post subject: Reply with quote
check your air filter that can be a cause of high co -i dont like to mess with the original settings because they are right and something else has changed.
brum brum
neo
PostPosted: Tue Oct 31, 2006 7:36 pm    Post subject: Reply with quote
Air filter is new.
bobbber
PostPosted: Tue Oct 31, 2006 9:18 pm    Post subject: Reply with quote
Steve is right.
Perhaps getting some abnormal readings from sensors.
Bob
Fiat Bravo 165 Sport
neo
PostPosted: Wed Nov 01, 2006 12:35 pm    Post subject: Reply with quote
I've checked everything. No errors on the ECU, all sensors reading normal. The thing is that this is not the original ecu instalation from my engine. It came from a donor engine. Including all sensors. So I don't even know if the setting on the MAF is factory.
stedee
PostPosted: Wed Nov 01, 2006 2:44 pm    Post subject: Reply with quote
hmmmmmmmmm i dont know which way to turn it but there are posts on here about adjusting the flap to trick the ecu that more air is coming in than really is maybe you could do the opposite its to do with a `w `spring that controls how much force is needed to open the flap on the maf.i think if you search under tuning you may find it
brum brum
johnboy
PostPosted: Wed Nov 01, 2006 9:28 pm    Post subject: Reply with quote
HI Neo
From memory,to make it leaner.you turn the screw anticlockwise. the oppersite if you had carbs on your car.as this on a carbed car would richen it up.
hope this helps. plus do the airflow mod,it works trust me Wink
regards john
WODA WE NEED? MORE POWER!!
1999 freestyle superjet
PostPosted: Mon Jan 29, 2007 7:38 pm    Post subject: Reply with quote
hey neo
I have the correct way to set up the idle mix screw at home somewhere, ill try to fish it it out.
Its something like screw all the way in until engine starts to hunt, then back 1/2 or a full turn.
I have also done the 5 min AFM mod Laughing make a mark where it is and move it anti clockwise up to 5 notches, iv done mine 5, some people have done it 3, try it see wotcha think.
Bellamachinna
PostPosted: Tue Jan 30, 2007 1:39 am    Post subject: Reply with quote
Hi all...
Just for curiosity...
How do you adjust the idle screw on the AFM????????????????????????
Do you get a real change in idle speed?????
I ask this, because, last Saturday, i took my 16v to a specialist, and he disconnected the idle actuator before adjusting the AFM, and then proceeded with the adjusting. After some seconds of ajusting he would blip the throtle (at around 3000rpm), and then restarted the adjustment...
I never used this method, and was used to adjust the idle screw only, without messing with any other ancialiaries. (with little sucess)
The idle was adjusted higher, and after connecting the idle actuator, it would calm down.
He repeted the process till the idle was "silk smooth"
Hope this helps
P.Camilo
