Two questions
micap
PostPosted: Fri Jun 13, 2003 3:46 pm    Post subject: Two questions Reply with quote
Yesterday I went to look at another 33, and it looked good compared to the one I have now. Engine went well, and the gearbox was still pretty sharp. But one thing concerned me when I drove it. When the wheels were fully turned at either left or right, a knocking sound appeared from somewhere in the engine compartment. I guess it's got something to do with the drive shaft. Any thoughts on this and how bad it is?
And then another question. When I corner or brake hard in my own car, the oil light comes on. Could this be serious or maybe just a bad connection?
/Michael
ex 89 1.7 QV
now 85 1.5 QV with 1.7 engine.
BILL
PostPosted: Fri Jun 13, 2003 7:22 pm    Post subject: Reply with quote
When you turn the wheels to the far end the p.s. pump is making this sound but when you leave the stearing wheel it stops but if the pump is worn out you ll hear the sound (not so loud) at any direction than str8 (my 33 does it so i ll change the pump with another one).
micap
PostPosted: Fri Jun 13, 2003 8:52 pm    Post subject: Reply with quote
It's a 89, so it can't be the power steering.
/Michael
ex 89 1.7 QV
RBL
PostPosted: Fri Jun 13, 2003 11:17 pm    Post subject: Reply with quote
dodgy cv joints ?
micap
PostPosted: Sat Jun 14, 2003 4:20 pm    Post subject: Reply with quote
RBL wrote:
dodgy cv joints ?
What exactly is a cv joint? And is it serious?
/Michael
ex 89 1.7 QV
Maximilian
PostPosted: Sat Jun 14, 2003 5:28 pm    Post subject: Reply with quote
You say that you only here the knocking on full lock?
Yes, that's a classic indication of CV joint wear.
I'm not sure about Alfas, but it wasn't that expensive to get them replaced on my Fiat Uno years ago.
http://autos.yahoo.com/repair/results/ques111.html
1988 Sprint 1.7 QV (35,000 miles)
gritsop
PostPosted: Sat Jun 14, 2003 10:42 pm    Post subject: Reply with quote
Hello,
Bill a question for you conserning the steering system:
Is this noise from the steering hearing like a wowing? How many kms have you done ?
I'm asking you this because two years ago (sept 2001 - 55000kms) i had problems with the steering system as it failed and it was sucking all the fluid of the reservoir! Thank God the repair of it costed only € 150
Do you know how much the pump costs? Can it easily be repaired?
Thanx in advance.
Thanassis Gritsopoulos
micap
PostPosted: Sun Jun 15, 2003 9:55 am    Post subject: Reply with quote
Well, guess it's the cv joints then. Will the drive shafts have to be removed to fix this. And any idea how much time it takes?
/Michael
ex 89 1.7 QV
RBL
PostPosted: Sun Jun 15, 2003 3:37 pm    Post subject: Reply with quote
Disconnect each axle at the outer end from the hub. There are 6 allen bolts going through the cv joint, undo and pull these out and the axle will come away from the hub. Check to see if the boot needs replacing, if they're broken it's probably this that's allowed water etc into the cv joint and caused the problem.
changing the cv's is a messy job - lots of black grease but it shouldn't be too difficult. I've just rebuilt the cv joints and replaced the boots which came with a pack of grease for each one. not sure how much cv joints are - £30+ each?
check the manual and have a go.
good luck, Richard
Gary UK
PostPosted: Sun Jun 15, 2003 4:28 pm    Post subject: Reply with quote
I think a Drive Shaft will be well over £150 each for the complete unit. Don't know if you can recon them.
Scott Sander
PostPosted: Sun Jun 15, 2003 11:36 pm    Post subject: Reply with quote
If you do the CV joints, be aware there is a circlip in the middle of them. You will need to undo this clip to replace them. If you don't you will break the CV joint trying to get it apart.
Scott Sander
http://www.sanderfamily.com
