dd (guesting) Guest
Posted: Tue Jun 17, 2003 9:33 am Post subject: Reverse Light Fuse on 16V SW |
Any clues about Reverse Light Fuse
I have an intermittant fault (mostly fault)
The fuse for Reverse Light is shared with
Rear Wiper Reset
Using Reverse Wiper does not cause fuse to blow
Using Reverse Gear causes Fuse to blow (10 times out of 11)
Hence I think fault in Reverse Light Circuit
Rear light cluster OK,
Reverse Gear Switch seems ok
No obvious breaks in the wiring
Any clues before I strip the inside out and trace the fault?
A further clue, Rear Wiper slows down when in reverse.
-- Thanks
dd (16V Sportwagon) |
dd (guesting again) Guest
Posted: Tue Jun 17, 2003 12:32 pm Post subject: Solved |
The Flying leads into the switch itself
were chaffing - now fixed
-- dd |
