16V engine
rsfruitbat
PostPosted: Wed Aug 15, 2007 7:21 am    Post subject: 16V engine Reply with quote
Anyone know what the sensors are for in the throttle bodies and heads. I assume assume one is water temp and maybe one is for overtemp but I am a bit stumped on the third. Any ideas? Rolling Eyes
tvatavuk
PostPosted: Wed Aug 15, 2007 7:25 am    Post subject: Reply with quote
Looking from front of car.
One on left top head is for water temp.
One in middle is for oil preassure warrning lamp.
One on right behind is for overheating lamp.
Tino Vatavuk
Ben_nz
PostPosted: Wed Aug 15, 2007 11:05 am    Post subject: Reply with quote
Weird! Why don't they just run the overheating lamp off the water temp sensor using a bit of electronics? That would be more reliable, cos you already know if your water temp sensor is working.
rsfruitbat
PostPosted: Wed Aug 15, 2007 1:20 pm    Post subject: Reply with quote
The one in the middle of the block is for oil pressure. Smile
In each of the throttle bodies there is a sensor which goes into the water flow. There is also a sensor which bolts onto the back of one of the heads. If one is for the water temp warning light and the other is for actual water temp what is the third for? Rolling Eyes
tvatavuk
PostPosted: Wed Aug 15, 2007 4:43 pm    Post subject: Reply with quote
Because rear part of boxer engine is one that heats most. Engine is water cooled but air flow also plays big role in cooling engine.
Tino Vatavuk
