spare wheel well full of water
PostPosted: Sun Apr 27, 2008 12:32 pm    Post subject: spare wheel well full of water Reply with quote
Hi everybody, as you all know I have been without my 33 for a good 5 months and haven’t been able to make a start on repairing it until yesterday.
Upon doing so my spare wheel well was full to the top with water.
I can’t figure out where this water has come from as any water dripping into the hatchback is channelled around and down towards the rear lights. There was no water on the parcel shelf and the windows are bonded. I was thinking maybe sunroof drains but the sunroof is closed and doesn’t leak and even if water does get in there surely it wouldn’t be enough to fill the whole spare wheel well.
I am at a loss, any helpful "bobbber" and serious suggestions.
johnboy
PostPosted: Sun Apr 27, 2008 1:18 pm    Post subject: Re: spare wheel well full of water Reply with quote
Hi chap
think the water comes in behind the lights
john
WODA WE NEED? MORE POWER!!
1999 freestyle superjet
PostPosted: Sun Apr 27, 2008 1:37 pm    Post subject: Reply with quote
Hi, Once you've bailed out the wheel well or drilled a drain hole - with a hand or airdrill- else Shocked , climb in the back and get an assistant to hose down the back.
Could also be boot seal, but lights are prime suspect as Johnboy said. You can seal the lights with dum-dum or even bathroom sealant.
PostPosted: Sun Apr 27, 2008 2:32 pm    Post subject: Reply with quote
Thanks guys, when the car is mobile again I will test with a hose for leaks around the lights. If it does leak I will probably replace the seals instead of bodging it Smile On the 8v there is a rubber bung in the bottom of the well but on the 16v it’s made of metal and I didn’t know and damaged it removing it, DOH!
eagle3
PostPosted: Mon Apr 28, 2008 3:06 pm    Post subject: Reply with quote
It could also be a rusthole in a wheelarch.
Alfa33 QO 1984
Alfa33 1.3i.e. 1994
gritsop
PostPosted: Mon Apr 28, 2008 3:57 pm    Post subject: Reply with quote
Ages ago I also had the spare wheel well converted in poll. A test from outside with the garden hose and me inside, prooved that the boot seal was the one to blame.
Replaced it with a new one and problem solved Wink
Thanassis Gritsopoulos
PostPosted: Mon Apr 28, 2008 8:58 pm    Post subject: Reply with quote
eagle3, the car has been stationary for 5 months Embarassed Wink
gritsop, i will test when its mobile again, not long i hope
PostPosted: Wed Apr 30, 2008 11:48 am    Post subject: Reply with quote
I think its coming from the rubber seal at the bottom of the window!! Surprised Crying or Very sad
bobbber
PostPosted: Wed Apr 30, 2008 12:45 pm    Post subject: Reply with quote
Al,
Probably the metal lip which the rubber sits over has rusted away.
Bob
Fiat Bravo 165 Sport
