Posted: Tue Sep 02, 2008 7:15 pm Post subject: |
hi,
1. lambda readings will be disregarded
2. the timing will be set to 97 RON
Posted: Sun Sep 07, 2008 4:49 pm Post subject: |
when checking the timing with a timing gun what readings should i see for 95 ron and 97 ron no cat, as in degrees?
With an alfa tester diagnostic attached what should i see for the same as above.
I want to make sure everything is where it should be.
Thanks _________________ x2 33 16v
Posted: Wed Sep 10, 2008 11:39 am Post subject: |
Zenith, is there any mod that can be done that allows 97 ron degree advance and lambda correction enabled, why wasnt that added as an option?
I believe that it should be 8 - 36 degrees on normal 95 ron _________________ x2 33 16v
Posted: Fri Apr 03, 2009 2:11 am Post subject: |
| BigAl wrote: |
| With an alfa tester diagnostic attached what should i see for the same as above. |
as in what should the ignition advance readout show _________________ x2 33 16v
