Dave_NZ Alfasud
Posted: Wed Jul 23, 2003 12:17 pm Post subject: how do i fix/shine my paint? |
I know that i have a clear coat on my Biano Argento (goldy silver) 33. What should i use to get the scratches out of the clear coat. They look like the sort of scratches you get on clear plastic, hence the clear coat. Or is it just best to give it a good waxing. I also need to patch up some battle damage (aka someones towbar) on the bumper. How would this be best done. Should it be primed then painted or done another way. Any help appreciated.
Dave
PS I want a really shiny turnout, no matter how long it takes. _________________ Looking for a type 2 33QV in NL |
Gary UK Alfa Sprint
Posted: Wed Jul 23, 2003 2:33 pm Post subject: |
| You need to prime the bumber with Etching Primer (a special surface preperation for aluminium, plastic etc.) otherwise the paint will just peel straight off. Then just paint as normal with a 2 pack paint. You can get the exact colour of you base coat mixed and put into an areosol at many paint shops in the UK so I would imaging you can in NZ too |
Dave_NZ Alfasud
Posted: Sun Jul 27, 2003 10:21 am Post subject: |
any advice on polishing the swirls and getting good shine.
thanks
Dave _________________ Looking for a type 2 33QV in NL |
Gary UK Alfa Sprint
Posted: Sun Jul 27, 2003 3:59 pm Post subject: |
| Plenty of elbow grease |
burgo90 Alfa Sprint
Posted: Sun Jul 27, 2003 9:29 pm Post subject: |
ive got a prob like this but mine is my laqure is comin off the bonnet and looks terrible ive tried t-cut and comma paint restorer but these dont touch it help!! _________________ http://www.novaload.net/features/viewfeature.php?ref=881 |
Dave_NZ Alfasud
Posted: Mon Jul 28, 2003 1:52 am Post subject: |
| Gary UK wrote: |
i know that ....but which product do i use to apply the elbow grease to my car.
Posted: Mon Jul 28, 2003 9:52 am Post subject: |
| burgo90 wrote: |
| ive got a prob like this but mine is my laqure is comin off the bonnet and looks terrible ive tried t-cut and comma paint restorer but these dont touch it help!! |
Hi there.if the lacqure is coming off,if your very carefull and litely sand down the bonnet all over, you mite be aball just to relacquer it.but dont go through the base coat.it can be done but you have to be very carefull.what you need to do is respray it.if you cant spray,it should cost you between £50-£100 to spray clear over base.thats the base coat and clear. hope that helps good luck john
33 16v veloce g 90 |
burgo90 Alfa Sprint
Posted: Sat Aug 09, 2003 10:13 pm Post subject: |
Dave.
With clear over metallic you can sand with 1000_1500 wet and dry and finish with hand rubbing compound.Take it slowly as you dont want to go through the clear coat or it will be patchy for ever more! If you can borrow a proper buffing machine then use machine compound as its finer.Keep the buff moving otherwise you can burn the paint surface.
Good luck Eddie |
