bobbber P4
Joined: 14 May 2003 Posts: 2162 Location: The Greatest Town on Earth - Swadlincote, UK
Posted: Mon Mar 30, 2009 12:33 pm Post subject: P4 Fuel Tank restoration |
My P4 tank is leaking, so I removed it from the car (oh joy, I loves working with petrol).
In the 33 manual, it says you can remove the top plate (the one which has the fuel hoses and the connection for the fuel level float) by removing six screws. My tank doesn't appear to have this :
Interesting. Is anyone else's P4 tank like this? I'm assuming, by the look of it, that it's a screw in thing... Should I unscrew it by hammering a screwdriver on one of the raised bits? Any ideas? I'm guessing there is a proper tool for this somewhere?
Bob _________________ Fiat Bravo 165 Sport |
bobbber P4
Posted: Mon Mar 30, 2009 12:41 pm Post subject: |
Ok, worked it out. The whole thing rotates. Screwdriver and hammer to turn it... and I'm your uncle.
lee16v 16 Valve
Posted: Mon Mar 30, 2009 12:44 pm Post subject: |
I would say you're right Bob. If it was me I'd be tapping it lightly on one of the three raised luggs anti-clockwise. From the pic the indents on the tank rim are there to stop the assembly over tightening. |
lee16v 16 Valve
Posted: Mon Mar 30, 2009 12:45 pm Post subject: |
My reply was too late uncle Bob! |
lee16v 16 Valve
Posted: Mon Mar 30, 2009 12:46 pm Post subject: |
I take it it's repairable then? |
Posted: Mon Mar 30, 2009 12:47 pm Post subject: |
to open it you place 2 small charges of c4, one to the left of the sensor and one to the right sorry bb timewasting whilst waiting for my flight!. _________________ PHAT 33 |
Admin Site Admin
Joined: 19 Feb 2003 Posts: 1223 Location: Stafford, UK
Posted: Mon Mar 30, 2009 12:52 pm Post subject: |
Yep, rotate it just don't break the part you rotate.
It is the normal cars that have the 6 bolts (maybe just carbed ones).
Good luck finding the hole.
All the best
Keith _________________ I owe, I owe, its off to work we go.
Bimota Forum
Stafford Christmas Lights
lee16v 16 Valve
Posted: Mon Mar 30, 2009 12:59 pm Post subject: |
There's six bolts on mine Keith so it's just different for the P4 |
bobbber P4
Posted: Mon Mar 30, 2009 2:40 pm Post subject: |
Yeah, I got the blighter off.
Going to restore with one of those "tank sealer" things (see if it works, I understand Gritsop has had good results using this technique).
I'm thinking about the best way to remove all the crud and rust from inside. Thinking of putting some stones inside, duct taping the holes up, and then shaking it around for a couple of hours!
I'll keep you all updated with the results. Thanks for the replies.
gritsop Green Cloverleaf
Joined: 23 Apr 2003 Posts: 766 Location: Ekali, Athens - Greece
Posted: Mon Mar 30, 2009 5:29 pm Post subject: |
Just adding some facts about tank restoration.
I have been restoring my tank for months and it is now ready to be installed on the 33. The tank I have was one of the last to be available from Alfa and within 4 years it leaked from the spot welds. So I decided to restore it properly and hopefully once for all using the fuel tank sealer kit.
Rougly the process was:
- soldered the bottom part with soldering iron on a radiator shop. There are quite some spot welds on the bottom due to the chambers separation on the inside; in total the radiator shop soldered all 16 spot welds. The welds are the first to rust from the inside
- cleaned the inside with marine clean; this product will remove all dirt even though you dont see dirt and crud with bare eye. Two or three times will give you a clean inside.
- Prepare the inside with Metal Ready. Prepared metal surface in order to successfully "accept" tank sealer. It also removes and neutralises rust
- Tank sealer. A magic liquid that will cover every mm of the inside. It is so strong that once it drops on your skin it will flake off after some days or if it stains your clothes then consider the stain permanent. One of my trousers still has a stain from tank sealer six months now. Once dry it has a very smooth finish feeling, so smooth like touching glass.
Optional steps.
Paint the external surface with POR 15 products. Rust preventative paint and Blackcote paint; very durable and anticorrosive methods.
Here are some pics during my restoration.
Soldered the spot welds
Dirt and crud removed with marine clean
Metal ready prepared surface
Fuel tank sealer just applied
Stripped and ready to paint with rust preventative paint
Rust preventative paint applied
Final painting and finishing
Now looking for a nice day to remove temporary tank and install the restored one. _________________ Thanassis Gritsopoulos
1991 Alfa 33 1.4 IE
2001 Alfa 147 1.6 Distinctive
http://www.alfa-restoration.co.uk
Parts Shop: www.alfa-restoration.co.uk/shop |
bobbber P4
Posted: Mon Mar 30, 2009 6:26 pm Post subject: |
Looks great.. .that's exactly what I'm looking for.
ZeNiTh-PbArM Alfa 33
Joined: 14 Mar 2003 Posts: 388 Location: Paris, France
Posted: Mon Mar 30, 2009 10:57 pm Post subject: |
For people who might be unaware of the involved risk, please DO NOT ATTEMPT TO WELD A FUEL TANK as it might explode. If i understood the explanation well this is due to the heat releasing some gas fumes from the metal which may cause the tank to blow up.
Have a professional shop do it (they use oxygen-deprived atmosphere) or replace the tank. A mechanic i know witnessed in his young days the explosion of a tank during welding, he said the guy welding the tank was literally cut in half by the metal fragments. If you still want to attempt welding a tank, you can fill it entirely with water and weld it while it's full of water.
regards,
zp |
Posted: Tue Mar 31, 2009 7:38 am Post subject: |
Gritsop,
I know you were starting with a newish tank, but that does look fantastic.
lee16v 16 Valve
Posted: Tue Mar 31, 2009 10:55 am Post subject: |
So Bob, what took Than 'months' to do you have to squeeze into 20ish days if you want to get to SAD? |
Posted: Tue Mar 31, 2009 10:57 am Post subject: |
He can make it within 20 days ... my "months" spam of time was just due to the fact that I have a tank borrowed from my friend Dennis, so I had all the time to restore it at my pace.
Regards, _________________ Thanassis Gritsopoulos
1991 Alfa 33 1.4 IE
lee16v 16 Valve
Posted: Tue Mar 31, 2009 10:59 am Post subject: |
Nothing like having lots of time at your disposal Than
Looks very good by the way. Hoping mine will resemble something like that when I do it! |
Posted: Tue Mar 31, 2009 11:08 am Post subject: |
Thanks guys,
Actually I will tell you the actual results when I install the tank on the 33 and fill her up
Regards _________________ Thanassis Gritsopoulos
1991 Alfa 33 1.4 IE
bobbber P4
Posted: Tue Mar 31, 2009 11:09 am Post subject: |
Lee, my little SAD/SPA timer tells me it's 32 days to SAD and 71 days to SPA.
I'll have that tank done soon... clocks have gone forward (extra evening time) and the weather is nice.
lee16v 16 Valve
Posted: Tue Mar 31, 2009 11:27 am Post subject: |
Well get off this site and get on with it then |
AlfaMack Alfa Arna
Joined: 08 Jan 2009 Posts: 17 Location: South Cheshire
Posted: Tue Mar 31, 2009 11:43 am Post subject: |
I take it the car failed it's MOT then Bobber?
The info about not welding a fuel tank is a good one. when I was in the RAF a guy was fixing his mini at the car club. Needed the fuel tank doing and proceeded to do it himself. The place emtied pretty quick when he started doing it! Got a right bollocking off the guy in charge.
Did the job though |
Admin Site Admin
Posted: Tue Mar 31, 2009 12:49 pm Post subject: |
Strictly speaking as it is the fuel vapour that is dangerous it would probably be safer to weld a tank full of petrol than one that had been emptied.
Not that I would want to try either.
All the best
Bimota Forum
Posted: Tue Mar 31, 2009 12:54 pm Post subject: |
In maritime literature when tankers need to be serviced or welded there is a process called "gas free" where fuel vapors should be eliminated before any job done.
This "gas free" procedure is done by filling up the tanks with water. Vapors are forced out of the tanks and thus being secure for welding.
I guess filling up the tank with water 2 or 3 times it can be considered safe to use welding.
1991 Alfa 33 1.4 IE
bobbber P4
Posted: Tue Mar 31, 2009 1:10 pm Post subject: |
I'm working on it Lee!
Right then.... done the first clean up. Took ages, but amazing what gunk will come off when you use a scourer and some washing up liquid :
Interesting discovery... someone has tried to seal this tank before (clearly failed!). It looks like putty in there!
Appears, whatever it is, to be pretty tough stuff though. Probably remove it as I want a totally "back to metal" tank before I do anything else.
Nothing more I hate than people sticking some shite on in an attempt to seal something.
Posted: Tue Mar 31, 2009 1:45 pm Post subject: |
Bobbber,
That 'shite' looks like Chemical Metal made by plastic padding, basically a pretty tough filler. Probably worth grinding it off.
Used it yesterday to stick some screws for legs onto a big red door knob that is now a ladybird in my son's Spring Parade at school. The lady birds spots were Alfa black, left over from a s2 33!
