Tighten clucth?
Errol
PostPosted: Sat Jul 19, 2003 9:18 am    Post subject: Tighten clucth? Reply with quote
My clutch pedal has about 3-4cm of play in it, and im wondering if i can tighten it from the pedal, not the actual main clutch set up. Because i cant get into that stuff, only simple things for me! Very Happy
91 Alfa Romeo 33 16v * SOLD*
Lowered 45mm
15 x 7 inch advanti wheels
Falken 195 low profile
K&N Pod filter
Cannon 2inch exhaust from cat-back with 3inch tip.
View user's profile Send private message Send e-mail AIM Address MSN Messenger
Jas
PostPosted: Tue Jul 22, 2003 12:59 pm    Post subject: clutch Reply with quote
the clutch is hydraulic, you can't adjust it as such. If it's just play, then have a fiddle with the pedal. Otherwise it's worn. any slipping?
Toad
PostPosted: Fri Jul 25, 2003 10:03 pm    Post subject: Reply with quote
try bleeding the slave cylinder
and check for any leaks, even very small one's
Shift for Brains
Luciano
PostPosted: Sat Jul 26, 2003 11:49 pm    Post subject: Reply with quote
Your problem is the pin that conects the pedal. You have to change it. It´s atached by a zeger nut.
I have the same problem now. If you dont change it one day it will break and you'll can't change gears.
I´ve done a Autocad drawing of it, to do a new pin, tell me if you want it.
Cheers
Alfa Romeo Trentatrč Q4 '94
Errol
PostPosted: Sun Jul 27, 2003 12:59 am    Post subject: Reply with quote
Yes that would be very helpful! Thanks!
Lowered 45mm
K&N Pod filter
