BILL Alfa Sprint
Posted: Thu Aug 21, 2003 7:08 am Post subject: REALIGNMENT OF WHEELS |
Im taking my car (33 1.4 ie 1992)for a realigment of wheels and i want to know if the 16V uses the same data for the camber caster e.t.c.
Becoase i have 14inc wheels, the shocks absorvers that the 16V uses.Or should i stick to the data for the 1.4ie.
Thanks in advance |
Posted: Thu Aug 21, 2003 4:00 pm Post subject: |
Bill, can you restate what you have written because i cannot understand what you want to ask !?
BILL Alfa Sprint
Posted: Thu Aug 21, 2003 4:55 pm Post subject: |
| After fitting new tyres im taking the car to the mechanik to check camber caster toe in .Are the mesurements the same for the 16V and for the 1.4? |
Posted: Thu Aug 21, 2003 9:48 pm Post subject: |
According to the workshop manual for the Alfa 33 s2 vehicles with engines of 1.2, 1.3 , 1.5, 1.7 the figures are the same for all cars.
toe out: 4 +-2'
toe out angle : 10'
camber angle : -1 degrees +-30'
caster angle: 2 degrees +-30'
Note: these figures are considered with static car load (about 75 kg in the passenger seats plus about 50kgs luggage)
Hope this helps.
