oil temp gauges
PostPosted: Fri Oct 26, 2012 2:21 am    Post subject: oil temp gauges Reply with quote
I have a few questions.
First is, which one?
1.
2.
PostPosted: Fri Oct 26, 2012 9:10 am    Post subject: Reply with quote
I prefer the look of the top one personally. The bottom one is a bit 'playstation' IMHO.
Is there one available from a late 80's early 90's alfa if they had them (75???) that might match the look and/or brand of what's in the 33?
John
PostPosted: Fri Oct 26, 2012 10:27 am    Post subject: Reply with quote
I like the fisrt one too, it's in keeping with my other 2 dials, jeager, I can't find an oil temp one the same Sad
eagle3
PostPosted: Sat Oct 27, 2012 4:14 am    Post subject: Reply with quote
I saw some older italian gauges on leboncoin.fr but the bloke wants €50 a pop Shocked Plus shipping http://www.leboncoin.fr/equipement_auto/249563080.htm?ca=5_s
Alfa33 QO 1984
Alfa33 1.3i.e. 1994
PostPosted: Sat Oct 27, 2012 7:25 pm    Post subject: Reply with quote
I will use what I have, thanks Smile
next questions Smile
Where do I put the sender?
1. in an oil sandwich plate?
2. http://www.ebay.co.uk/itm/Sump-Plug-Sensor-Adaptor-Oil-Temperature-Gauge-Sender-/370668179443?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item564d8b8ff3
3. http://koni-centre.com.ua/pro-sport/images/pribory/T-4_450.jpg
I have an oil pressure gauge in the top back of the engine and will eventually fit an oil cooler, not got the sandwich plate yet.
33bits
PostPosted: Thu Nov 01, 2012 6:13 pm    Post subject: Reply with quote
Have a look at my M reg 16v Al, that has oil pressure & temp gauges. (of coarse i'll have to get it running 1st, not long now)
155 sportpack
PostPosted: Thu Nov 01, 2012 6:55 pm    Post subject: Reply with quote
yeah but does it work? lol
33bits
PostPosted: Thu Nov 22, 2012 11:27 pm    Post subject: Reply with quote
She is now back on the rd & running well, both extra gauges work fine Very Happy
155 sportpack
PostPosted: Fri Nov 23, 2012 12:55 am    Post subject: Reply with quote
sweet, so how is it wired up?
33bits
PostPosted: Sat Nov 24, 2012 8:59 pm    Post subject: Reply with quote
There is a blanking plug next to the oil filter, i removed that & fitted a temp sensor. The oil pressure gets it's reading from the sensor in the middle of the block, i removed the original sensor from the top of the block & replaced it with a bigger type sensor that had an extra screw hole in it, so it kind of converts 1 threaded hole into 2, works a treat. Very Happy
155 sportpack
