stevecarrcross Alfasud
Posted: Tue Sep 24, 2013 9:35 am Post subject: any ideas |
Ok
Have Compression with the finger test?
waiting for my official tester to come so i can do a proper test (what would you expect)
have fuel
have spark
but when i remove the lead the engine doesnt miss fire unlike with the other three cylinders
running twin 45's (is it poss flooding the engine with fuel on that one cylinder?
any ideas
Steve |
Posted: Tue Sep 24, 2013 8:09 pm Post subject: |
Blocked idle valve, quite common among the webber carbs. Are you using twin 45 Idf's on a 1300cc engine? seems perhaps a tad too big unless you have re-jetted to suit. _________________ PHAT 33 |
Brit01 Gold Cloverleaf
Posted: Tue Sep 24, 2013 9:10 pm Post subject: |
compression finger test??
Literally?
even 50 psi would blow your finger off the hole and 50 psi will not fire. _________________ S2 33 1988 1.7 QV
Posted: Wed Sep 25, 2013 4:59 am Post subject: |
Oggie wrote: |
Blocked idle valve, quite common among the webber carbs. Are you using twin 45 Idf's on a 1300cc engine? seems perhaps a tad too big unless you have re-jetted to suit. |
I think they're Dellortos but yes not original.
Not quite sure what you mean by
Quote: |
but when i remove the lead the engine doesnt miss fire unlike with the other three cylinders |
I would check compressions(could be one timing belt(usually right bank) one or two teeth out of sync) and ignition timing first. Firing order 1 3 2 4. If that's ok probably a carb issue. _________________ Alfa33 QO 1984
Alfa33 1.3i.e. 1994 |
Posted: Wed Sep 25, 2013 6:36 am Post subject: |
When I remove each lead individually the engine drops as its only firing on the other three cylinders with the faulty one there is no change in engine note hence mowing its not firing,
I think the engine has had work done on it as like you say 45's would be far too big
Waiting for compression tester to arrive |
Posted: Wed Sep 25, 2013 6:37 am Post subject: |
Ps it's the cylinder closest to oil filler back left if looking from gearbox |
Posted: Wed Sep 25, 2013 7:01 am Post subject: |
Morning
If there's no change in revs when you pull the lead , then there's on spark or fuel! Recheck your lead and plug _________________ WODA WE NEED? MORE POWER!!
Posted: Wed Sep 25, 2013 7:57 am Post subject: |
have checked spark, and its good and strong
and plug is wet when you take it out,
im thinking too much fuel is just flooding the spark out |
Posted: Wed Sep 25, 2013 8:44 am Post subject: |
Very strange Have you tryed turning the jets in a tiny amount? _________________ WODA WE NEED? MORE POWER!!
Posted: Wed Sep 25, 2013 2:34 pm Post subject: |
sounds similar to my recent issue.
When I checked compression it was very low so it was not firing properly. Had fuel and a good spark.
Have you changed the spark plug?
When its running what do you see down the barrel? fuel is coming out? _________________ S2 33 1988 1.7 QV
Posted: Wed Sep 25, 2013 4:07 pm Post subject: |
It could still be the timing belt. Won't know until compression test.
If the belt's out by a tooth the compression on one of the two will be appreciably lower. The other one on that bank may still have enough compression to fire.
I wouldn't mess with the carbs until compression and ignition has been checked. _________________ Alfa33 QO 1984
Posted: Thu Sep 26, 2013 1:38 am Post subject: |
Years ago a 33 I know of had the timing belts replaced by a dealer with one bank being 1 tooth out. Ran remarkably well.
As to the carbs, that does sound a bit big. Car jetting (that I could find) is listed here:-
http://www.alfa-pages.co.uk/carbjet.php
JeremyC Gold Cloverleaf
Posted: Thu Sep 26, 2013 8:20 am Post subject: |
Yes when Adie Hawkins did my belts he found that one of them was out by a tooth and it ran fine. It had either slipped or been built like this at the factory! _________________ '93 Black 33 1.7 16v |
Posted: Thu Sep 26, 2013 8:53 am Post subject: |
Ok. Two teeth maybe?
There must be some difference in compression surely.
If the carb was flooding you'd expect both cylinders to be affected no? _________________ Alfa33 QO 1984
Posted: Thu Sep 26, 2013 12:57 pm Post subject: |
If the belt were out it would affect both cylinders on that bank. Go too far out and it will bend the valves.
I must admit with the carbed engines whenever I had a misfire of any kind I tended to swap the plugs, distributor cap, rotor arm and HT leads before bothering to look anywhere else (had a misfire with the Maserati once and went to do the same until I found out a distributor cap was around £250, and a rotor arm a further £95 ).
Posted: Thu Sep 26, 2013 1:35 pm Post subject: |
Admin wrote: |
Yes of course the pistons will eventually touch the valves. Both cylinders are affected but one more than the other.
Look here. French forum but hopefully you'll get the jist. Two teeth out but no damage done apparently. Note compressions. http://www.carb.fr/forum/viewtopic.php?f=34&t=10827 _________________ Alfa33 QO 1984
Posted: Thu Sep 26, 2013 5:22 pm Post subject: |
It shouldn't affect one cylinder more than the other. They both should suffer the same ill effects.
