The Wombat Alfa Sprint
Posted: Mon Nov 11, 2013 9:09 pm Post subject: |
crowbar and sharp knife!!!
Or if you want it in one piece, it is actually very easy.
- Steering wheel and steering cowl off.
- All the lower dash off - its all self tapers but be careful not to break any plastic tabs
- Glove box lid off
- Windscreen vent out the top
- Take the instrument binnacle off - couple of self tapers but be careful with the wiring as its fragile
- Depending on model, centre vents out
- Then there is a big screw at each end of the dash hidden by the door
- Look carefully under the dash for a number of bolts holding the dash on
- It should now start to feel loose and you can find the other bolts by careful wiggling and seeing what is holding it on
IIRC that's about it _________________ Drivers:
- Green Fiat 20VT Coupe
- Champagne 155 V6
- Winter Freelander
- Mrs Wombats Freelander
Projects:
- Various 33s
- Some 155s
Hibernating for 2015
- 75 3.0 Cloverleaf
- 155 Q4 Winny
- Red 33 16v |
