Another one not starting
Goto page Previous  1, 2
Ian M
PostPosted: Sat Feb 01, 2014 9:25 pm    Post subject: Reply with quote
johnboy wrote:
Are your carbs blocked? Have tried Squirting some fuel down the inlets to see if it fires then dies Wink
Carbs not blocked, see above.
I've even tried easy start and it won't fire.
Heidi I'm seriously considering it
Presntly own
Red Abarth 500c
PostPosted: Sat Feb 01, 2014 10:33 pm    Post subject: Reply with quote
Yeah are the plugs still dry / can you smell petrol on them?
eagle3
PostPosted: Sun Feb 02, 2014 5:39 am    Post subject: Reply with quote
The spark timing wouldn't be out by 360 degrees would it? That is the spark is at the end of the exhaust stroke instead of the compression stroke.
Are you getting any firing at all(like flames coming out the exhaust, pops and bangs)??
When you say the spark is "good" what colour is it? Might be worth trying another coil and electronic ignition module.
Alfa33 QO 1984
Alfa33 1.3i.e. 1994
Ian M
PostPosted: Sun Feb 02, 2014 12:02 pm    Post subject: Reply with quote
I've been out again this morning in the sunshine
Spun it over while pumping the throttle, then removed plugs which are drenched in fuel as you would expect.
Then I tested for a spark again, even in the bright morning sun I can see a good bright spark (no not Big Al), I also checked that it is timed correctly ie at approx tdc dizzy points to no1.
Tried changing it by 180deg where it was chuffing and banging out of the exhaust, so it must of been right.
I just don't understand why it won't fire or even make some attempt to fire.
Presntly own
Red Abarth 500c
Ian M
PostPosted: Sun Feb 02, 2014 12:56 pm    Post subject: Reply with quote
Had a plug out again and had a good long look at the spark.
I would say it is variable and jumps about not firing at the same place on the electrodes.
Does this point towards the coil/electronic ignition module?
Is the module the thing mounted under the coil?
Is it still possible to get them?
Presntly own
Red Abarth 500c
eagle3
PostPosted: Sun Feb 02, 2014 1:56 pm    Post subject: Reply with quote
The module should be something like this(french site)
http://www.webdealauto.com/fr/appareil-de-commande-systeme-d-allumage/valeo-245510.932.402997.96.html
I think I have one in the barn. And a coil come to that.
Alfa33 QO 1984
Alfa33 1.3i.e. 1994
Ian M
PostPosted: Sun Feb 02, 2014 3:32 pm    Post subject: Reply with quote
Thanks eagle just had a look on eBay and it's all available new and reasonably priced.
May even be able to get from a local factors
Presntly own
Red Abarth 500c
PostPosted: Sun Feb 02, 2014 6:10 pm    Post subject: Reply with quote
Make sure both carbs aren't flooding with a constant drip. ??
ZeNiTh-PbArM
PostPosted: Sun Feb 02, 2014 9:55 pm    Post subject: Reply with quote
Timing belts still in place? Engine timing correct between crankshaft and both camshafts?
How old are spark plugs? Sometimes if they are the resistive type they can get badly damaged during cranking attempts with the engine flooded and although they exhibit good spark, they won't fire the engine. I once spent some time on a non-starting GTV6 that way. Replacing all six plugs got it to fire right away!
zp
PostPosted: Mon Feb 03, 2014 10:39 am    Post subject: Reply with quote
Spark, fuel, timing, compression and air.
Maybe no air Question Confused
Ian M
PostPosted: Sat Feb 08, 2014 4:45 pm    Post subject: Reply with quote
So new coil and module arrived Thursday and between storms today (Saturday) I managed to fit the coil as I felt this was the most likely culprit.
Battery a bit week, due to lack of charging and a lot of fruitless attempts at starting, so after connecting a spare it fired straight up.
Left it running while I refitted the airbox etc.
Then got in put in gear and off we go, bit rough at first but after a couple of miles sweet as ever.
And once the brakes cleaned up I was able to stop Laughing
Anyway I've put the swan vestas away for the time being.
Presntly own
Red Abarth 500c
PostPosted: Sat Feb 08, 2014 6:07 pm    Post subject: Reply with quote
Sorted.
I'll send you a SAE for the matches if you don't need them anymore Wink
eagle3
PostPosted: Sat Feb 08, 2014 6:25 pm    Post subject: Reply with quote
Well done.
So it's not sure whether it was coil or module. Very Happy
OOPs sorry misread it. It was the coil.
Alfa33 QO 1984
Alfa33 1.3i.e. 1994
Brit01
PostPosted: Tue Feb 11, 2014 2:23 pm    Post subject: Reply with quote
Excellent! Unusual for those coils to go.
S2 33 1988 1.7 QV
Page 2 of 2
