Posted: Wed Oct 01, 2014 2:06 pm Post subject: Misfire when pulling left. Any ideas? |
Leads are all secure and I can't see any coolant leaking from header tank onto coil. No problem turning hard right. What is going on?
Any ideas? _________________ Owner's Club 33 Registrar. Now from P4 & S2 1.7 QV
Ian M Green Cloverleaf
Posted: Wed Oct 01, 2014 6:25 pm Post subject: |
Float levels? _________________ Presntly own
Red Abarth 500c |
Posted: Thu Oct 02, 2014 7:57 am Post subject: |
How would that effect only turning one way?
Did you have this problem with the car before Ian or is it something that I might have done? _________________ Owner's Club 33 Registrar. Now from P4 & S2 1.7 QV
Johnpm1967 Alfasud
Posted: Thu Oct 02, 2014 12:16 pm Post subject: |
Must be electrical? What about jacking up and putting on full lock. Any earths or leads being touched or shorted.
Floats would only be if hard corner so that one side suffers too much or little fuel. |
Posted: Thu Oct 02, 2014 5:41 pm Post subject: |
No Paul not a problem I ever had with her and as you know I cornered her quite hard from time to time _________________ Presntly own
Red Abarth 500c |
Posted: Fri Oct 03, 2014 8:08 pm Post subject: |
Perhaps a worn out fuel pump diaphragm?. _________________ PHAT 33 |
Posted: Fri Oct 03, 2014 10:10 pm Post subject: |
Not something simple like fuel starvation from the tank with a dodgy pickup? |
Posted: Sat Oct 04, 2014 11:14 am Post subject: |
Check carb floats first and fuel circuit.
Other than this, i experienced a similar problem long time ago. Turned out to be a dead battery, plates inside would move a little bit under centrifugal force and short the battery. Found this while driving the car with a voltmeter hooked between coil + terminal and chassis ground.
Posted: Sun Oct 05, 2014 8:48 pm Post subject: |
Interesting one zp. I just bought the battery new so should be ok??
Pretty sure it's lateral G rather than steering lock.
Surely if it were floats or weak pump it would misfire turning either direction.
Not really sure how to work out what is going on let alone rectify it.
Will have a look at the carbs and check everything. _________________ Owner's Club 33 Registrar. Now from P4 & S2 1.7 QV
Posted: Fri Oct 10, 2014 9:17 am Post subject: |
Plan routes with right hand turns- simples.
Seriously though in addition to what others have said how about water (puddle water or coolant) getting into or sitting in the left hand side plug holes? _________________ If it aint broke, fiddle with it until it is!
