first start of rebuilt engine!
RBL
PostPosted: Sat Oct 04, 2003 1:37 pm    Post subject: first start of rebuilt engine! Reply with quote
I've just re-fitted my rebuilt 1.7 8v engine (from my old '89 Sprint) into the Porsche spyder replica I'm building.
(http://www.pbase.com/550joe/owner_spyders. Mine's the uncompleted one at the bottom - click on pic for more details ).
Now I've fitted the engine I want to start her up to check she starts/runs ok (finger crossed!) but I haven't fitted the cooling system yet. Would it be ok to start and run it for a few minutes without any coolant in the system? I really want to hear it start up!
Obviously the water pump will be spinning but there'll be no water in engine. If the thermostat isn't supposed to kick in 'till 81-85 degrees I should be ok shouldn't I??
thanks, Rich
rjbevan
PostPosted: Sat Oct 04, 2003 2:55 pm    Post subject: Reply with quote
If I were you I wouldn't try it without coolant in the engine. There would too much of a temptation to not stop! Why don't you plumb everything up but just connect the radiator hoses together (i.e. no lines to the front of the car).
Richard
Ian M
PostPosted: Sat Oct 04, 2003 3:03 pm    Post subject: Reply with quote
I personally wouldnt riskit.
Just think how you would feel after spending all that time and money and then damaging it for a moment of impatience.
Presntly own
Red Abarth 500c
graeme
PostPosted: Sat Oct 04, 2003 3:39 pm    Post subject: Rebuild Reply with quote
I just fitted my 16v after rebuild. I didn't connect any hoses or put any water in or connect the exhaust before I knew it would start and run JUST FOR A FEW SECONDS. Then I connected the stuff up.
16v p4 In pieces.
BILL
PostPosted: Sat Oct 04, 2003 9:24 pm    Post subject: Reply with quote
DONT TRY IT!! You will do more damage than good(the sound of the engine working).It takes seconds for an engine to overheat and you will have to rebuild it again. It wont be more than half an hour to connect all the hoses and the radietor .The thermostat needs coolant to work or else how it knows the temp Question
BILL
PostPosted: Sat Oct 04, 2003 9:32 pm    Post subject: Re: Rebuild Reply with quote
You are lucky you didnt get a fire in your garage without the exhaust.From what i know its very difficult for an engine to start and then idle right without the exhaust(no buckpressure Question im not sure).
Anyway the damage that has been done inside the engine is not noticesable from the begining,is comes out later.
graeme
PostPosted: Sat Oct 04, 2003 11:08 pm    Post subject: Rebuild Reply with quote
Didn't let it idle. Just made sure it fired. That's like 2 seconds. There's a lot of cast iron that would't get slightly warm in that time. After full assembly the engine then ran and reved supperbly, with no knocks, bangs or smoke.
16v p4 In pieces.
RBL
PostPosted: Sun Oct 05, 2003 3:57 pm    Post subject: Reply with quote
Thanks for your replies - Yep! you're all right - it's not worth rushing it. I'll get the cooling system sorted first
Rich
