33 1.5le rear break drums
PostPosted: Wed Mar 14, 2018 4:38 am    Post subject: 33 1.5le rear break drums Reply with quote
How the hell do i get my break drum off jst dicoverd a leak n cnt get the drum off to see whats causing it
PostPosted: Wed Mar 14, 2018 4:40 am    Post subject: Re: 33 1.5le rear break drums Reply with quote
love the car but nly had it a week n already gt issues lol
Oggie
PostPosted: Wed Mar 14, 2018 10:10 pm    Post subject: Reply with quote
You should only have to remove the centre wheel bearing nut and washer , make sure the hand brake isn't on and pull the drum off.
PHAT 33
RFlower
PostPosted: Thu Mar 15, 2018 7:46 am    Post subject: Reply with quote
Make sure the handbrake cables are slack, loosen the adjustment nuts behind the handbrake lever and/or disconnect the cables at the back if necessary.
If the drum is very worn there may be a ridge behind the shoes making it difficult to get the drum past them. In this case keep turning the drum as you gradually work it off over the shoes.
If there is a ridge, have the drums skimmed if the inside diameters are within tolerance - the maximum is shown on them, or preferably, replace them.
I have found drums which are skimmed are sometimes not perfectly round, probably due to worn-out equipment.
Dick Flower, Nr. Carcassonne. '94 Trofeo 1.4 ie (F), '93 Imola 1.3/1.4 ie (now for parts) (F), '91 1.7 ie (GB)(spare car), '86 Sprint 1.5 QV (F). '87 VW Syncro camper (F), '96 Audi Avant 1.8T (F)
