Use 8v fuel tank configuration for 16v
Martini SE
PostPosted: Mon Nov 10, 2003 2:39 pm    Post subject: Use 8v fuel tank configuration for 16v Reply with quote
Hi everyone!
I have a problem with the fuel return on my 16v fuel tank. I suspect my tank is a modified 8v tank with an added fuel return pipe to fit the 16v fuel circuit. The added pipe is welded very close to the tank and when i bent it upwards to get more room to fit a new hose and clip it must have cracked. Now all return fuel is evidently not getting back in the tank. I've tried twice to cover it with some leak-fix but the smell unveil it did not work for long.
I then came up with the idea to switch the connections between the ventilation and the fuel return. A meter of hose is cheepier than a new tank. Razz From the workshop manual what is the ventilation pipe on the 16v seems to be the fuel return on the 8v. Is that correct or will there be problems if i switch them? Confused
Until i fix this I drive with constant full throttle to limit the amount of fuel in the return circuit Twisted Evil Morning traffic is a nightmare Shocked
Only Kidding, but help is appreciated!
Best Regards,
Martin
Alfa 33 16V QV -91 (Martini Bianco)
johnboy
PostPosted: Mon Nov 10, 2003 11:54 pm    Post subject: Re: Use 8v fuel tank configuration for 16v Reply with quote
HI there,
when i did my 16v conversion,i kept the 8v tank and i have had no problem's what so ever driving fast or slow. the return on the 8v goes into the filler pipe not the ventilation pipe i'm sure.
hope this help's let me know how you get on Wink
all the best
john
WODA WE NEED? MORE POWER!!
1999 freestyle superjet
Mixsynth
PostPosted: Fri Nov 14, 2003 1:51 pm    Post subject: Reply with quote
I would suspect that with a leaky tank you aren't safe just not using the connector you cracked. When you fill it up all the way it will be spilling out whenever you throw it round a corner. It's best just to get a replacement.
I have a spare 8V/16V tank I want to shift... mint condition... Smile
Hugh B
'98 145 QV
16V conversion pics/videos - now updated with extra pictures and explanations
Martini
PostPosted: Tue Nov 18, 2003 11:58 am    Post subject: Thanks Reply with quote
I'll see what I'll do, I'm not sure. A hose reconfiguration wouldn't be solid safe I know but the crack is so small i guess some pressure is needed for leakage. I'll probably end up buying a used tank from someone closer but anyway, thanks for the offer Smile
However, I was about to change plugs and oil and noticed I have a mayonaisse-in-the-oil-fill-pipe problem to solve before I change the tank. Hopefully that is just because it has been rainy and I've driven very short trips this week. -Fingers crossed-
Martin, Sweden
