Posted: Thu Dec 11, 2003 5:29 pm Post subject: Timing please! |
Finally getting the engine going after sitting for a long time and I think it needs a good tune up.
Can anyone tell me what the timing should be set to? Dwell?
It's a 1.7l 8V with twin dellortos carbs...
Cheers
Rich |
Posted: Thu Dec 11, 2003 10:07 pm Post subject: |
Hi Rich
Dwell is non adjustable with electronic ignition. Timing marks are on the flywheel under a round plastic cover near the dizzie.
Posted: Fri Dec 12, 2003 9:19 am Post subject: |
Cheers, I can build the cars but when it comes to tuning I'm hopeless! My mechanic neighbour just asked me to get the tuning specs so he can do it, is there anything he needs to know other than the timing marks on the flywheel?
Thanks,
Rich |
Posted: Fri Dec 12, 2003 10:38 am Post subject: |
hi
First mark 8degrees btdc at idle or static
Second mark( if there are 3)22degrees btdc at 2000 rpm
Third mark( or second if only 2) max advance 36 degrees btdc at 4500 rpm
Hope this helps
Regards Eddie |
Posted: Fri Dec 12, 2003 10:47 am Post subject: |
Thanks a lot for that, should do the job
Rich |
