Lazy rev counter
PostPosted: Fri Dec 12, 2003 3:27 am    Post subject: Lazy rev counter Reply with quote
My S2 1.5 33's tachometer has started responding really slowly, both counting up and down. When I change gear it's still counting up and it takes about a minute to float back down to the lower engine speed. I've tested the coil connections and they seem fine.
Is it the gauge itself?
Thanks,
Brent.
johnboy
PostPosted: Fri Dec 12, 2003 12:11 pm    Post subject: Re: Lazy rev counter Reply with quote
Hi brent
not much help, but if your counter is nackered i have a S2 speedo and rev counter.p.s. check the conections behind the dash,it's just two screws to take off the cover.
hope that help's john
WODA WE NEED? MORE POWER!!
1999 freestyle superjet
