Dicko Alfasud
![](images/avatars/2134291834416b3e22da26.jpg)
Posted: Sat Jan 17, 2004 3:14 pm Post subject: Ronal A1's??? 15 x 7 on a 33? |
SERIES 1 qv
ANYONE GOT ADVICE BEFORE I PURCHASE?
any experience on lowering with these rims??? and tyre sizes//
Appreciated.... RIch ![Exclamation](images/smiles/icon_exclaim.gif) |
paul D. Guest
Posted: Sat Jan 17, 2004 6:30 pm Post subject: Ronal's on 33 |
on my series 3 (lowered 35mm) I notice very little rubbing on the outside of the rear wheel arches when under heavy load. On the front side I've had the prob that with new brakepads and discs the brake caliper touched the inside of the wheel..... so had to rub little material away from caliper for clearance wich never gave me probs.
Regards!
Paul D. '93 16V QV |
James Granger Alfa 33
Posted: Sun Jan 18, 2004 11:14 pm Post subject: |
Optimal tyres are 195/50 and you could do with 35 mm spacers all-round. |
alfistjen Alfasud
Posted: Mon Jan 19, 2004 6:29 pm Post subject: spacers not adviced |
as the wheels are now allready standing wider on the car, the outside of the tire scrubs the outside of the wheelarch, front works with the wheels just aligned with the arches, maybe a very flat spacer could do the job with the brakes in front, but from the moment the pads are used 1mm the problem is gone.
Anyway, the Ronals look great on a 33, they're worth a bit of work. Good luck in finding them and putting them on the car!
Regards!
Paul D. |
paddy granger Alfa Sprint
![](images/avatars/151547687642511de39465c.jpg)
Posted: Tue Jan 20, 2004 9:14 am Post subject: |
Here are some pics to persuade you!
![](http://classic2.alfisti.net/media/tuning_styling/33/33ronala105.jpg) |
Micke G Alfa Arna
Matt Stolton Alfa Sprint
Posted: Tue Jan 20, 2004 10:47 pm Post subject: I have done similar... |
Without having to use spacers, and with -35mm springs on, I have got 195/45 R15 A259 Yokos on some rather nice OZ rims on my P4 project. I believe they are 15"x71/2J too!! If I recall they are ET35, and were fitted to a Lancia Dedra originally. The 45 profile gives you a little more clearance, and gives you a little acceleration back, making your diff last a little longer too.
At the front I have about 10mm clearance to the nearest thing which is the strut. At the rear it is about the same, perhaps a little tighter, and is close to the trailing arm, and clears the strut nicely.
Simple advice, buy them. it doesn't matter if they don't fit, they are possibley the nicest looking wheels for a 33 going. They are the right age for the car, right stye, just get them and worry about fitting them afterwards!!! If you don't get them, I'll have them!!! _________________ Regards
Dicko Alfasud
Posted: Wed Jan 21, 2004 10:15 am Post subject: Thanks... A-nuts. |
This info is great... found a set in Sydney... would prefer the 14"... but...
They may cost me almost a thousand AU. with rubber.
Hmmm
Dick |
Buck Bundy Alfasud
Posted: Mon Jan 26, 2004 2:18 am Post subject: Ronal A1 |
I must admit I'm quite taken by the A1s on the Red Sprint on the Alfapower site.
My 1982 Sprint has a bodykit fitted which I'm not sure I want to keep. The front spoiler I like, but the extended wheelarches look a bit naff with the original 13inch Campagnolo alloys. I can't use the front spoiler without the wheelarches, but now I've seen the A1s I'm back to thinking that I might keep the kit.
Its that old question of whether to keep it original or not.....?
Posted: Mon Jan 26, 2004 9:27 am Post subject: |
I have lowered the red Sprint 35 mm and with 195/50 15 tyres and Konishocks it is very fun to drive in clubracing here in Sweden.
The engine is a standard 1,7 118 hp with Ansa extractor. The fronspoiler is an original from 1978 and the rearspoiler is from Zender. The bumper is also original 1978. My plans is to mount C&B kams and shave the heads for a lite more compression. The car is even now very fast on small racetracks and Porsche turbos have big trubles to pass me. I hope to get about 30 more new horsepower and after that the car would be a pain in the *** for most Porsches and bigger Alfas.
Micke G |
