tone Alfa Arna
Joined: 13 Mar 2003 Posts: 20 Location: perth (australia)
Posted: Sat Jan 24, 2004 10:14 am Post subject: jet sizes ? |
hi
can anyone tell me the standard 33 jet sizes for 36mm and for 40mm dellortos and webers.
thanks  |
Posted: Sun Jan 25, 2004 8:50 pm Post subject: |
Hi Tone
Depends on the engine size.Herewith specs for DRLA 36 as fitted to S2 1500.
Main venturi 30
Aux. venturi10078.01.68
Main jet 1.22
main air corr. jet 1.80
Emuls. tube 9164.02.28
Idle 52
Idle air corr. 220
Progression holes 100-160-160-180-180-
Accel. pump jet 0.33
Accel pump del 7-9 (cc per 20 strokes)
Needle valve 150
Float weight 10gms (important!)
Choke jet 0.80
Choke air corr 7482.03.28
Float level 5-6mm (carb face vertical, distance between float and gasket withe float tab just contacting the needle valve .)
Posted: Mon Feb 02, 2004 10:15 am Post subject: |
thanks very much for that
tone |
Dicko Alfasud
Posted: Tue Feb 03, 2004 12:55 am Post subject: Haynes manual |
If you get a chance to pick up a Haynes Manual - Alfa Sud/sprint
1974 - 1988.
get it.
It has a supplement section with info on engine codes for sprints (same as series 1 33). Lots of dual carby 32 / 36 webber and delloto info.... no 40's.
Maybe not accurate for series 2 33 and up.
If it helps... try Ebay. |
Dicko Alfasud
Posted: Sun Feb 15, 2004 2:58 pm Post subject: Haynes Manual: for sale |
example: saw this on EBay.. not mine.... has useful section on SUDS and extra on late model SPINTS - up to 1490cc. Handy carbi info....
GOod for S1 33s.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=2460442328&category=9903 _________________ Too Many!! 33 QV 1.5 1986 (day driver, Sud 1.5 82 (toy) and Sud Ti Qv 84 (on hold), 1988 1.7 carbie too (wobly). |
