water pump problem with removing
vassil
PostPosted: Fri Apr 11, 2003 8:04 pm    Post subject: water pump problem with removing Reply with quote
I have a 33 1.3 sport wagon 4x4. While I was driving a strange noise appeared. It is like tapping. In the beginning it was rare but it began to appear all the time. When I stopped I found out that water trickles from the water pump and its pulley shakes with the pivot. The problem is that I can’t remove the pump. I removed the pulley, unscrewed the four bolts from the block but the cover of the pump couldn’t budge. Would you tell me how can I remove the pump?
Thanks in advance
PostPosted: Fri Apr 11, 2003 11:00 pm    Post subject: Reply with quote
These are known for being difficult. As a worst case scenario I knew one mechanic who said just to hit the pump repeatedly with a large hammer, working on the basis that the alloy pump would shatter before the iron block
The problem is the alloy pump and iron block fuse together
I think some people have had some success making a tool to grip onto the 4 mounting holes for the pump and then trying to twist it
neo
PostPosted: Sat Apr 12, 2003 10:24 am    Post subject: re Reply with quote
Hi !
I recently had to change the waterpump on my 33. I had to remove the bumper, mask and the water cooler. The pump was so stuck that I couldn't even move her. I had to crush her on the engine and take her out in pieces. It took about 4 hours to do that. I had to be careful not to damage the block.
I hope I'll never have to change the pump again.
