electrical woes
Post new topic   This topic is locked: you cannot edit posts or make replies.    Alfa Pages Forum Index -> Boxer Workshop
Dave_NZ
PostPosted: Sat Feb 07, 2004 10:39 am    Post subject: electrical woes Reply with quote
Hi all. I went to start my car today and all that happened was the doors locked. I figure that there is an earthing problem and that the central locking is shorting out on the ignition wires somewhere. can anyone suggest where i can begin looking. This is the first major electrical problem i have had so i hope to find a solution soon. thanks in advance.
Dave
Looking for a type 2 33QV in NL
box_me2
Guest
PostPosted: Sun Feb 08, 2004 8:01 am    Post subject: electrics Reply with quote
Hey Dave.
Alfa’s are well known for their amazing electrics,
I also have a problem with my left rear indicator, it seems to have a “lazy eye” that is when it is turned on it also lights up the tail light, resulting in a dull indication and when applied with the break no indication at all… all the globes are fine can anyone help? (sorry I was no help)
Ben_nz
PostPosted: Sun Feb 08, 2004 11:30 am    Post subject: Reply with quote
I think I've heard of that one before, you have to check the earthing of that tail light module. Bad connections cause one circuit to earth back through another and both bulbs light up, or something. =|
Dunno about your problem Dave.. My central locking locks itself when I open the passenger door wide, but fortunately the car still starts.. Rolling Eyes
Ravi
Alfa Arna
PostPosted: Sun Feb 08, 2004 11:20 pm    Post subject: Reply with quote
Dave - can't help you with your problem mate - sorry!
Ben - your door electrics problem is easily fixed. I had the same thing happen with mine.
The problem is because the plastic conduit running between the door and the front panel of your car has broken and or fallen off. This normally protects the wiring and stopping it from coming into contact with the metal bodywork of the car when you open the door.
I found by simply wrapping up the wires with insulation tape where they were touching the door stopped the problem... Not sure what the electrical cause is however - perhaps an earthing or conducting effect?!
Cheers
1986 33 QV
Looking to upgrade to a 16v?...
Post new topic   This topic is locked: you cannot edit posts or make replies.    Alfa Pages Forum Index -> Boxer Workshop All times are GMT + 1 Hour
