Lamba probe output pattern
Marcin
PostPosted: Mon Mar 31, 2003 11:49 am    Post subject: Lamba probe output pattern Reply with quote
I've question about the lambda probe. I've been measuring the voltage between the probe's output wire and probe's ground wire. So far I know nearly 0 volt stands for rich mixture and nearly 1 volt for lean. What I found was the multimeter showing nearly 0V, then a short pulse to about 0.6V and back to zero. This pattern repeated itself continiously. I don't know how to interpret this. I would expect some oscilations, but more in the mid range when in idle, and falling back to zero for a while only on pressing the accelerator.
Any hints?
Thanks,
Marcin
neo
PostPosted: Wed Apr 09, 2003 10:48 am    Post subject: re Reply with quote
Hi!
You may encounter some problems with the lambda on idle if the engine is cold or the outer temperature is cold because lambda probe works only when hot. Try connecting the multimeter from inside the car and then go for a ride. When driven the engine produces more heat on the exhaust. If the lambda is dead even then, you will have to replace it.
Marcin
PostPosted: Wed Apr 09, 2003 2:57 pm    Post subject: Reply with quote
actually I did warm the engine up before my tests, so that shouldn't have caused the problem. I was just wondering if it's the normal response of the probe, that I measured. My car has done nearly 210.000km, so I'm wondering if the probe is ok, or is it ready for replacement. I suspect the car of running rich.
Cheers
Marcin
Scott Sander
PostPosted: Wed Apr 09, 2003 9:41 pm    Post subject: Reply with quote
I thought the probes were only good for 100K. Maybe worth replacing it.
Scott Sander
http://www.sanderfamily.com
timo a.
PostPosted: Sun Apr 13, 2003 9:08 pm    Post subject: re Reply with quote
The lambda probe is not necessarily broken. It might be that the ECU is not controlling the mixture properly (i don't know if this is common or not).
Anyway the lambda probe is fairly cheap and easy to change so it might be good idea to change it.
BTW. If i'm not mistaken 0V is lean mixture and 1V is rich mixture.
