jmmoss Alfa Arna
Posted: Tue Mar 16, 2004 1:05 pm Post subject: Shell Optimax:An amazing turn around now my 33 much faster! |
Hi there,
Just filled up with Shell Optimax after being slightly disappointed with the performance of my "new" 1987 1.5 33 and the difference immediately is superb - much better acceleration and response - it put a smile on my face all the the way home. Here in Australia it is 10 cents more per litre, but I think the fun factor, plus the fact it is better for the engine (cleans it as you drive) and boosts mpg slightly means it is worth it. Have any of you tried it yet? _________________ Alfa 33 4c 1.5 Gold Cloverleaf 1987
with Air Conditioning |
Ken McCarthy Alfa Sprint
Posted: Tue Mar 16, 2004 11:22 pm Post subject: Shell Optimax |
I have been using it for some time and am happy with it. I changed the octane setting on the engine computer to get maximum advantage. Fuel consumption was about 11 Km per litre before the speedo went on the blink. _________________ Ken McCarthy - 16V Sprint |
Matty Dog Alfa Arna
Joined: 07 Dec 2003 Posts: 21 Location: Wellington, New Zealand
Posted: Wed Mar 17, 2004 2:33 am Post subject: Re: Shell Optimax |
Ken McCarthy wrote: |
I changed the octane setting on the engine computer to get maximum advantage. |
How do you do that?
Matthew |
Posted: Wed Mar 17, 2004 7:17 am Post subject: Shell Optimax / Octane setting |
Matthew
There is an electric bridge that looks like a relay in the bulkhead area in front of the firewall. It can be replaced or modified to set the computer mapping for various octane ratings. Have a look on Scott Sander's site at http://sanderfamily.com/
Look under alfa things then ignition advance. (ed. mod)
Errol Alfa Sprint
Posted: Thu Mar 18, 2004 2:37 am Post subject: |
I use BP ultimate in my 33 16v, and is the only fuel that is actually 98RON, Optimax is 97RON. _________________ 91 Alfa Romeo 33 16v * SOLD*
Lowered 45mm
15 x 7 inch advanti wheels
Falken 195 low profile
K&N Pod filter
rjbevan Alfasud
Posted: Sat Mar 20, 2004 12:39 am Post subject: |
Errol, you must be sold short in Australia! In the UK Optimax is greater than 98 RON and is supposed to be the highest octane rating sold in the UK. Although if you can use leaded (i.e. no cat), then that is about 99/100 RON as they start with unleaded and add to it. But it's not easy to find and is not cheap. I once paid 95p per litre!
I only run my 1.5V engine on Optimax and it runs fine. The previous owner used to add octane booster to Lead Replacement Petrol. I haven't tried BP although that is the nearest one. Maybe will give it a go.
Richard |
Posted: Mon Mar 22, 2004 11:10 am Post subject: |
I too have started to take the Optimax route.
My 1.7 boxer engine kept "sludging" up, requiring oil changes about every 5000km to keep it quiet(ish!)...
I've found it to be a little quicker and I think better for the engine. _________________ Fiat Bravo 165 Sport |
Errol Alfa Sprint
Posted: Mon Mar 22, 2004 12:31 pm Post subject: |
Different country Different petrol! Its been tested here and they only got 97RON out of it. BP ultimate was the only one that had a 98RON rating. _________________ 91 Alfa Romeo 33 16v * SOLD*
Lowered 45mm
K&N Pod filter
Posted: Tue Mar 30, 2004 10:33 am Post subject: |
The relay modification on sanderfamily.com
Does it imply for 97RON fuel the relay should be removed?!?!?
Is this the same for the 8v engine?! _________________ Fiat Bravo 165 Sport |
