Ravi Alfa Arna
Posted: Wed Apr 14, 2004 12:07 am Post subject: Electric Windows |
Hey all,
After much fiddling and make shift remedies, I finally have got my 1986 style, series I, power windows working again. I tell you - those dash mounted buttons and contacts are an absoulte b*tch!!
Next task - now that I have the windows working again, they move REALLY slowly. What would my fellow Alfisti suggest in this regard? New motors from a jap/later model car?
Cheers _________________ 1986 33 QV
Looking to upgrade to a 16v?... |
Posted: Wed Apr 14, 2004 1:55 am Post subject: |
Are they moving really slowly because the window mechanism is very stiff and the motors too feeble by design, or because there are too many poor connections and voltage drops in the circuitry (meaning motors can't get enough power and new motors might not help)?
Are they still slow when the engine's running?
I've had no trouble from my electric windows yet (aside from poor connections in the fusebox), fingers crossed. |
Rob (Perth) Guest
Posted: Wed Apr 14, 2004 6:31 am Post subject: |
I think Ben has hit on the most likely cause for slow operation - low voltage supply thanks to additive bad connections in the circuit. It would be worthwhile to clean up all the connectors, or better still, replace them with new (and maybe some of the wiring at the same time). Also don't forget that the copper wiring in older cars oxidizes over time and causes resistance - apparently newer automotive wiring is better. Don't forget the fusebox - your '86 Alfa probably has the torpedo shape fuses which make very poor electrical contact at the best of times - clean up the contact surfaces there too.
I have a series 1 Alfa 33 too (1984) and both original window winders have failed. I replaced the driver's side winder with a manual winder (imported from Italy), but the passenger side I replaced with a winder from a series 3, which was MUCH better made than the series 1 winders. The window operation is much faster with this winder, so I'd recommend you keep a look out for newer replacement winders.
Also, the window track gets gummed up with junk over the years. You could try brushing the felt parts of the track with an old toothbrush (fairly stiff bristles needed, so paintbrush not suitable). You'll find a surprising amount of dust comes off when you do this. You can also try spraying the tracks with silicone spray, but I'm not sure this has helped my windows at all.
Rob |
Rob (Perth) Guest
Posted: Wed Apr 14, 2004 6:33 am Post subject: |
PS
If you are lucky enough to find series 3 winders, try to get hold of the mechanism complete, not just the motor. It is one helluva bitch to dismantle and reconnect the Bowden steel cable - I know!
Rob |
Ravi Alfa Arna
Posted: Thu Apr 15, 2004 2:43 am Post subject: |
Thanks for the advice guys. Ben - you may well be right, I didn't think about the possibility that the circuitry was inefficient. Although, the windows wind up and down at the same speed whether the engine is on or off. Maybe they were always that slow?
In any event, I am going to disassemble the door and window panel, clean everything out, and then put it all back with loads of foam padding to stop rattles.... I HATE RATTLES!!
I still have this mystery squeak in the back of my 33 that I cannot find for the life of me!! I even had a mate in the back looking for it as I drove over bumps!
Cheers
R _________________ 1986 33 QV
Marcin Alfa Sprint
Posted: Thu Apr 15, 2004 7:33 am Post subject: |
Quote: |
I still have this mystery squeak in the back of my 33 that I cannot find for the life of me!! |
Sounds familiar, I think it's the rear springs or suspension bushes.
Marcin |
BILL Alfa Sprint
Posted: Thu Apr 15, 2004 12:17 pm Post subject: |
Marcin wrote: |
Marcin |
Or from the brake valve(front/rear balance ). |
Posted: Thu Apr 15, 2004 7:06 pm Post subject: |
Yea Bill's right - check the spring that connects to the brake pressure regulator. Under the regulator there is a seat like an upside U that holds in place the spring (the one that "understands" the load of the car and thus the brake pressure needed for the rear wheels).
I also have this problem and the short term solution is to place grease over the union of these two; but after some days dirt etc. start again the noise.
What I plan to do is take from the tyre shop an old tyre tube , cut it and fold it twice and then place it between the regulator and the sring. Who knows it may do some trick...
Ravi Alfa Arna
Posted: Fri Apr 16, 2004 2:58 am Post subject: |
Do you guys mean the brake proportioning valve? I could have sworn this noise was coming from inside the car - near the parcal shelf or something.
The squeak almost acts like a "speed limit" device. As soon as I hit about 100km/h, the squeak kicks off in a big way. Must be something to do with the vibrations at those speeds.
If it was anything under the car, I reckon it is most likley to be the suspension / bushes. What's the best way to fix this if so? A bit of grease on the springs and bushes?
spider59 Guest
Posted: Sun Jun 20, 2004 2:28 am Post subject: rear squeak ! |
The only squeak I have not been able to eliminate from my 33 is one that comes from the rear hatch rubbing on the rubber seal. Put some silicone on the seal and if the noise goes away this is your problem and I havent found a sloution other than to keep spraying with silicone |
Posted: Thu Jul 01, 2004 12:05 am Post subject: |
The fold down backrests can also squeek if not latched properly.
