Dean131066 Guest
Posted: Wed Jul 21, 2004 2:12 pm Post subject: P4 breaking for spares |
I have a 1991/J 33 Permanent 4 (red) which I have been breaking for spares and it still has many useful parts.
The car will be scrapped next week as I need the space so I would rather see the remainder going to "committed" Alfa owners than being dumped.
Move quick if you are looking for spares.
Dean 07790 813795 |
ak863 Guest
Posted: Thu Jul 22, 2004 8:25 am Post subject: |
Hi Dean,
i am looking for back suspension in a good state..
However i have an 1.7ie (series 3). Would a P4 suspension fit?
let me know,
ak |
dean131066 Guest
Posted: Thu Jul 22, 2004 1:08 pm Post subject: rear suspension |
I'm almost certain that the rear shock absorbers will be the same. However, the rear end of a P4 sits slighly higher than a standard car and I'm pretty sure the springs are longer to achieve this. I do have some Koni springs and shocks if you are interested which will lower the back end about 1-2" from standard. I've tried this set up before and found the ride quite hard, but it would be ideal if you are into track days. |
Posted: Thu Jul 22, 2004 11:41 pm Post subject: |
Where are you based? Is the car already in pieces?
I could do with the rear gearbox mount, viscous coupling mounts and som front springs.
dean131066 Guest
Posted: Fri Jul 23, 2004 9:49 am Post subject: P4 parts |
The rear gear box rubber is chewed up! The rear donut rubber on the viscous coupling is totally shot although I did purchase a new one along with the centre bearing from an Alfa Dealer recently without any problems and the cost of £50 for both made it worthwhile. The front viscous coupling mount is usable although the rubber does have some cracks. I tried to purchase a front rubber from a dealer and was told that they are no longer available in this country. The cost of £90 also put me off! Personally I would remove the old one and take it to a specialist who could probably make a new rubber for a fraction of the cost! I have some P4 front springs although I am keen to keep them unless you are prepared to offer a sensible price. |
Posted: Sun Jul 25, 2004 12:22 pm Post subject: |
I would definatly be interested in the viscous coupling mounts, even the front one as as least I then have a pattern I can get copied (if I can find someone) without having my car off the road for a few weeks.
I have some struts with springs so I am not desperate (just I am not sure how good these springs are).
Paul Lewis Alfasud
Posted: Wed Jul 28, 2004 10:28 pm Post subject: Do you have the AFM? |
Hi there. I am in need of a decent Air Flow meter for my 16 valve. Do you have one and how much?
Cheers Paul. _________________ Currently own a late 33 16 Valve (M reg) in Silver, with P4 alloys and superspint back box.
I live out in the sticks with not an Alfa specialist for miles around!! |
Matt Stolton Alfa Sprint
Posted: Thu Jul 29, 2004 4:59 pm Post subject: Silly request |
Have you got a dipstick. I am after a non electric one, as I'm having a whole heap of alfa fun with mine currently
If you could PM me with cost and availabilty, I would appreciate it. _________________ Regards
RpmHead Alfasud
Posted: Fri Jul 30, 2004 1:27 pm Post subject: |
Hi Dean,
have you got the all black front door panels without any speaker holes in it? If so, I'm very interested in it.
Here is a picture of the door panel:
http://www.andycam.net/albums/album28/Image33_003.jpg _________________ Stian Henriksen, Norway
'92 33 QV S 16V
'66 Giulia Sprint GT Veloce
'69 Giulia Super |
