Paul Lewis Alfasud
Posted: Mon Jun 14, 2004 9:40 pm Post subject: ECU tuning chip for sale . |
HI All. I have a chip for sale which came out of the ECU from my crashed K reg P4. I am almost certain that it is an aftermarket chip, as it has a handwritten sticker on it saying 33 16 Valve. Also my P4 drove very well and was very quick and it had none of the hesitancy or jerkiness associated with the 16 valve engines. Come to think of it the engine noise was different too. The garage I use for repairs and servicing seems to think it is an aftermarket chip too and I would have fitted it to my current M reg 16 valve, but that has a CAT and the P4 didn't so the garage reckoned it wouldn't work. Anyone want to make an offer??
Also I have several other bits and pieces for sale including an OMP back box for a 16 valve (not the P4!!) - open to offers and I also have the 4x4 ECU (rear one) from the P4 for £20.
Other bits:-
Mk2 leather steering wheel £5
'Permanent 4' rear hatch script £10
some trim bits, rear light cluster etc- just ask!
Cheers Paul |
Posted: Tue Jun 15, 2004 11:09 pm Post subject: 16 v chip |
Hi Paul
I hope this doesn't burst your bubble but my chip also has a hand written label saying 33 16v. Could they all be like that? I too was convinced that it was an aftermarket chip but now I'm not so sure. Do your numbers match these?
SC0009 147
6512MD2 BBR'93
28/01/1994 AR
33 16V
Does anyone else know any better? |
Posted: Wed Aug 04, 2004 8:31 am Post subject: |
my P4 also came with chip inside ECU.
Hand written
S37D
33 16v.
So it may be that many P4 came from factory with hand written 33 16v label on chip.
And this one had fuel cut off which made P4 rather jerky. _________________ Tino Vatavuk
ALFAQV Alfa Arna
Posted: Wed Aug 11, 2004 8:21 pm Post subject: |
i opened up tje ECU yesterday to put a squadra chip in and i also found a handwritten chip with say's 1.7 16v _________________ Greetings from Holland ,
Dave ARTC 172 |
Matt Stolton Alfa Sprint
Posted: Thu Aug 12, 2004 9:15 am Post subject: Have you still got your gearbox... |
I may well be after your ECU for 4x4, but have you also got your electro magnetic coupling available? Does it come away from the gearbox easily, and could/would you sell it seperately? _________________ Regards
dean131066 Guest
Posted: Thu Aug 12, 2004 2:42 pm Post subject: Electromagnetic Coupling |
I have two spare gearboxes from a 33 P4. Both are in working order and comlete with the electromagnetic coupling on the back. Please feel free to contact me if you are still looking.
Dean 07790 813794 |
dean131066 Guest
Posted: Thu Aug 12, 2004 2:43 pm Post subject: Re: Electromagnetic Coupling |
| dean131066 wrote: |
Dean 07790 813794 |
Got my number wrong! Should have been 07790 813795 |
Posted: Sat Aug 14, 2004 2:51 pm Post subject: Thanks |
Dean - I have left a message on your answerphone with my work number on it, please give me a call with how much you want, and where I can collect from, and I will probably have one. I need to do some miles on my P4 to finish the running in, so distance isn't (too) much of a problem. _________________ Regards
Paul (not logged in) Guest
Posted: Tue Aug 17, 2004 10:35 am Post subject: Hi Matt |
| Hi Matt. If you still want the 4x4 ecu (rear unit) then give me a call on (01690) 770300 Cheers Paul. |
baiones Alfa Sprint
Posted: Tue Aug 17, 2004 2:25 pm Post subject: |
Hi Paul!
I'm interested in teh 33 MK2 leather wheel .
Can you send a picture to me so i check it's condition ?
baiones@netcabo.pt
How much if you send it to Portugal , Lisbon ? _________________ Carpe diem!!
Baiones
ALFA ROMEO 33 1.5 QV
ALFA ROMEO 33 1.7 QV
ALFA ROMEO 33 s16 QV
ALFA ROMEO Sprint 1.3
ALFA ROMEO 156 SW "Train Edition" ( it's a JTD... ) |
Posted: Wed Aug 18, 2004 1:05 am Post subject: Cheers |
Dean - Many thanks for the box, will help me out a treat. Best of luck keeping yor two P4 running, they looked very clean...
Paul - Sorry mate, but got a 4x4 ECU from Dean as well. _________________ Regards
Deano Alfasud
Posted: Wed Aug 18, 2004 8:37 am Post subject: Brakes |
Matt - Always a pleasure to meet another Alfa owner.
I would be very interested to know how you did your front brake coversion. And I'm sure many other 33 drivers would like to know as well! So if you have a few minutes to spare perhaps you would be kind enough to post an article which explains the set-up, who supplied the parts, what it would cost...etc.
Many thanks. Dean |
baiones Alfa Sprint
Posted: Sat Aug 21, 2004 12:09 am Post subject: |
I'm still interested in the wheel . Do you still have it for sale ? _________________ Carpe diem!!
Baiones
Posted: Fri Sep 17, 2004 2:07 am Post subject: Brake mods |
Dean - I did post some pictures in the general section, it features a picture from under the car, which shows the caliper and the bracket, from behind the wheel.
I wouldn't use an alfa 75 caliper again, as parts were a nightmare to source, such as the pistons, seals and anti-rattle pad retaining pins etc. The better/cost efficient option would be to use a caliper from the people who made the bracket and disc. They were highspec motorsport (.co.uk if memory serves), who do a range of parts/calipers that will fit under any wheel/strut combo.
The following picture is of the caliper, but my server is down for the moment, so look back at some point in the future, I'll fix it when I'm back from NY.
