Replacing Cambelt
Post new topic   This topic is locked: you cannot edit posts or make replies.    Alfa Pages Forum Index -> Boxer Workshop
bobbber
PostPosted: Fri Dec 03, 2004 12:08 pm    Post subject: Replacing Cambelt Reply with quote
I'm about to embark on a cambelt change....
So I thought I'd give you all the chance to brag on how quick you can do it, before I get started!
Fiat Bravo 165 Sport
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
LDA
PostPosted: Fri Dec 03, 2004 12:11 pm    Post subject: Reply with quote
did it on an mr2 turbo the other week. omg that was hard work. we had to take the engine out to do it!!! took me 2 days! to get the belt on and then i still had to put the lump back in!
not tried it on an alfa yet. but when i build a turbo lump i'll have to do it.
good luck, and do post back to let some of us people know where you got stuck and what to look out for.
L.
A good workman allways blames his sh*t tools.
LDA
PostPosted: Fri Dec 03, 2004 12:12 pm    Post subject: Reply with quote
oh and tippex!
mark the cams wheels with tippex and a little mark on the block too. so you line them up if they get moved.
L.
evanbottcher
PostPosted: Fri Dec 03, 2004 12:56 pm    Post subject: Reply with quote
Under the cam covers there is a notch at the rear of the cam housing that lines up with a notch on the rear of the cam itself, they line up when cyl 1 is at TDC on compression. It comes with it's own tippex!!!
Smile
http://www.trofeoalfasud.com
'77 Alfasud Ti
'69 1750 GTV
Ben_nz
PostPosted: Sat Dec 04, 2004 12:28 am    Post subject: Reply with quote
I hope you're going to change the belt tensioners too so your engine doesn't self-destruct like mine did! 5 months after the garage replaced the timing belts, the motor started sounding and running bad and then crack bang, I needed a replacement engine. Sad
evanbottcher
PostPosted: Sat Dec 04, 2004 1:24 pm    Post subject: Reply with quote
I wrote the following article on changing cam belts for our local Alfa club magazine:
http://www.trofeoalfasud.com/index.php?option=com_content&task=view&id=30&Itemid=73
might help?
cheers,
Evan.
'77 Alfasud Ti
'69 1750 GTV
johnboy
PostPosted: Sat Dec 04, 2004 5:46 pm    Post subject: Reply with quote
LDA
if you check old posts by me and others you should find how to do 16v belts.this is the only car i have ever done the the belts on.its easy when you know how too.i killed 8 valves on one side and bent one on the drivers side which a mate straightened. but it was only slightly bent.i rebuilt the engine in the car in the road out side the house. that was a year ago and she still fine! Cool
regards john
WODA WE NEED? MORE POWER!!
Alfa gt jtdm blackline
1990 S2 16v veloce sleeping!
2002 ts gtv the wifes now
1997 seadoo gsx 800
1999 freestyle superjet
ZeNiTh-PbArM
PostPosted: Sun Dec 05, 2004 9:39 pm    Post subject: Reply with quote
hi,
a few pictures can be found here too :
http://alfaimola.free.fr/technique/moteur/dist/index.html
regards,
zp
Post new topic   This topic is locked: you cannot edit posts or make replies.    Alfa Pages Forum Index -> Boxer Workshop All times are GMT + 1 Hour
