dtm Alfa Arna
Posted: Sun Dec 12, 2004 2:26 am Post subject: Odometer problems |
Hello,
I have a 1992 Alfa 33 1.5ie and the odometer stopped working. Any ideas?
Thanks |
GaryUK Guest
Posted: Sun Dec 12, 2004 6:11 pm Post subject: |
It's broken!! |
dtm Alfa Arna
Posted: Sun Dec 12, 2004 7:56 pm Post subject: |
I now that. How do I get it to work properly again? The thing is electrical, and I want to now if any of the gays out there now how to get it working whit out having to go to an electrician. They charge about 60euros to get it fixed.
Thanks. |
David Alfa Arna
Posted: Mon Dec 13, 2004 2:11 am Post subject: |
Excellent typo. |
Marcin Alfa Sprint
Posted: Mon Dec 13, 2004 8:57 am Post subject: |
I think he means the thing that counts the total number of kms, not the speedo. My works fine, but if would break I'd just get an other dashboard from the scrapyard, if I couldn't fix it myself.
Marcin |
dtm Alfa Arna
Posted: Mon Dec 13, 2004 10:12 am Post subject: |
Thanks Tino, the second post helped. That’s exactly the problem whit the Speedo. |
johnboy 16 Valve
Posted: Mon Dec 13, 2004 11:06 am Post subject: |
Hi dtm
i had the same problem with mine some time ago,when i took it apart, one of the wires had come off that powers the mileage counter.so i just soldered it back on. now its fine. easy job now on to all the others
1999 freestyle superjet |
Vecchio Alfisti Alfasud
Posted: Mon Feb 28, 2005 12:08 pm Post subject: |
To the moderators or anyone who knows what may be going on!
I have a similar problem with my speedo. It is unpredictably intermittent. The search function does not work and the 2 links given above do not seem to work. Have I been cut off?
Help please. Where to next?
Vecchio Alfisti. _________________ Alfa 33 1.7 QF I think maybe now I m not so sure |
Posted: Mon Feb 28, 2005 12:21 pm Post subject: |
Current version of board moved from phpbb2 to new folder phpbb3.
I repaired links, so you should be able to read them
As you might notice we had problems with Alfa Romeo 33 board 2-3 weeks ago & search wasn't functional.
You can read it all in:
http://www.alfa-pages.co.uk/viewtopic.php?t=1992 _________________ Tino Vatavuk
Posted: Mon Feb 28, 2005 8:20 pm Post subject: |
David wrote: |
Excellent typo. |
Sorry for this 'spam' message, but I am cracking up too |
Posted: Tue Mar 01, 2005 4:11 am Post subject: |
Thank you Tino.
I eventually found the posts and pulled the connectors apart this am. That seems to have worked as an immediate fix. Probably the act of separation and joining again did enough cleaning to improve the contacts. Now for the nail varnish remover. _________________ Alfa 33 1.7 QF I think maybe now I m not so sure |
